Thread: FAS/DPD Chlorine & CC's test - Sample Tube Question
    Jul 2012
    Dallas, TX
    179
    Hi,
    I'm about to order the FAS/DPD Chlorine & CC's test kit and have a question about the Ch Sample Tube.
    - Does this tube base fit on the Speedstir base? I think it does as that's mentioned in the Kit Hardware description page on the site. Just wanted to verify.
    - Would the Taylor Sample Tube (P/N 9198) work as a substitute for the one that's included in the kit? I see that the Taylor tube mark limit is 25 mL but it includes a 10 mL measuring line for the Ch Drop Test amount.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: FAS/DPD Chlorine & CC's test - Sample Tube Question
    Yes it does fit on the speedstir base. I *think* the Taylor one does also if its the same one that came in my Salt Test Kit?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Pretty much every sample tube I've had fits the speed stir. I even drop the pill in the CYA mixing bottle and let stir that as well.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2012
    Dallas, TX
    179
    YippeeSkippy & msgtdan
    Thanks for the info . I think I'll try the Taylor Tube at first to see if it's easier to read since the Tube that comes with the kit is incremented up to 40 mL and the Taylor Tube that I have is incremented up to 25 mL. That may make it easier for me to see the 10 mL sample contents.
    [edit] After looking closer at the Taylor Tube, I'm guessing that it'll be the same as what comes with the kit since the 25 mL mark is only halfway up on the Taylor Tube so I'm thinking that both Tubes are the same height/volume.
    Jan 2012
    7,364
    My chlorine test tube is easier to read the numbers which are in black. The Taylor one is harder for me to read as the numbers are basically colorless and just raised looking.
    Jul 2012
    Dallas, TX
    179
    Quote Originally Posted by YippeeSkippy View Post
    Good point. I didn't notice that earlier, the one included in the kit has black marker labels.
