Thread: Poooooooooool Boy
    Poooooooooool Boy
    Hello all,
    I've had a pool my entire life however we always had a company take care of it. Now that I own my first house I find I don't want to pay for a pool service as my parents did. I am here to do 2 things:
    1) Learn how to maintain my pool
    2) Attempt to heat my pool on the cheap
    Wish me luck!
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Poooooooooool Boy
    Welcome aboard. Ask anything you want.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Welcome!
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome!
    Start with the ABCs in Pool School. Order a proper test kit ASAP, and as mentioned you can ask anything about pools you'll need to know here on the forum. Good luck, and enjoy our site.
    Essential Links:
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    Welcome - I think you'll find the advice here to be spot-on and easy to accomplish.
    I'll weigh in on the "heat the pool on the cheap" part. We have a 400,000 btu propane heater & attempted to warm the pool enough to swim over spring break. After sucking on propane for 24 hours, it resulted in a chilly dip, then a quick move into the attached spa. If I recall correctly, I think it only raised the temp 10 degrees - 0.5 degree / hr. About 40% of my 250 gallon tank was used in the process. My vote, based on this experience is this is not the "cheap" way to heat a pool. Maybe I'll learn some tricks here too!
    The spa on the other hand... Heats to 100+ in about 30 minutes and barely registers anything consumed on the propane gauge!
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    May 2015
    Chicago, IL
    508
    Welcome to TFP Lunarpancake!
    Glad you joined us, enjoy your summer, pool and your time on TFP!
