Thread: Wondering If My Pump And Filter Are Properly Sized
    Jul 2015
    Midland, MI
    3
    The house we moved into has a 24' above ground pool. I don't know much about pools, but in the reading I have done, it seems like the pump might be overrated for the system that is in place.
    The Pool:
    24' Diameter
    54" Average depth
    15,293 gallons (if my calcs are accurate)
    The Pump:
    Hayward SP1580
    1 HP
    Head/Flow
    10 ft / 86 GPM
    20 ft / 86 GPM
    30 ft / 75 GPM
    40 ft / 58 GPM
    50 ft / 27 GPM
    The Filter:
    Hayward S180T
    150lbs sand
    Designed flow rate - 35 GPM
    The Chlorinator:
    Hayward CL200
    The Hoses:
    1 1/2" flexible hoses
    Skimmer to Pump - 6 ft
    Pump to Filter - 6 ft
    Filter to Chlorinator - 6 ft
    Chlorinator to Pool - 3 ft
    If someone more knowledgeable than I could let me know if there are some things that I should change to help with overall efficiency, I would greatly appreciate it.
    30,403
    Re: Wondering If My Pump And Filter Are Properly Sized
    Welcome to the forum.
    The first thing that jumps out is, unfortunately, the most expensive fix.
    You could use a larger filter. Your pump is trying (and capable) of pushing about 60 or so gpm and your filter is only rated for 35 gpm.
    Your psi is likely close to 20 so you could get much more flow and less psi with a bigger filter rated at maybe 80 gpm or so.
    As an aside, it looks like you are using pucks. read "The ABC's of Pool Water Chemistry" up in Pool School. It may change your mind.
    Jul 2015
    Midland, MI
    3
    Thank you!
    Excellent guess. The gauge reads ~21 PSI. If I do replace the filter, is it still acceptable to use 1 1/2" hoses for everything?
    Thanks for the tip. I will give it a read.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Dave, nice seeing someone recommend a larger filter. The 180T will be a workhouse and need cleaning often. Installing a S210T will help with flow and frequency of backwashing.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    22,542
    If you're going to change the filter, look around at the S210T or the S220T and get whichever is the best price. It's probably going to be the 210, but it's a good idea to look around.
