Thread: Solar cover breaking down, plugs filter.
    Jul 2014
    Oakbank, Canada
    389
    Over the last week, could not figure out where these "flakes" were coming from, thought it was from one of the trees. They kept getting sucked into the filter, past the skimmer basket, and plugging the sand filter.
    Lo and behold, it was my old clear solar cover starting to disintegrate and the bottom of the little bubbles were falling of it! Floating on top the water, they were sucked into the filter system, and plugged it pretty good. I was trying to get one more season out of it, but its really bad now, so off to the store today to get a new one.
    So just a word of warning to keep an eye on your old covers, replace them.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Re: Solar cover breaking down, plugs filter.
    Pardon my ignorance, but what is a solar cover for? My first thought is the block the sun and protect chlorine.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Jul 2012
    Chicago, IL
    356
    Darrel - just curious how old the cover is? It seems that solar cover's life is typically around 3 seasons before they start to fall apart and that is regardless of the thickness.
    Razorhog- Solar covers help maintain pool temps, it is basically a large blanket that covers the pool surface. They really do their work by preventing heat loss at night, rather than capturing solar rays and adding heat during the day. They should probably be more properly called lunar covers! They do have that effect of blocking the sun and reducing chlorine loss, but that is incidental to their real purpose.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Thanks for the explanation. I think I need the opposite! Water temp is currently 84F which is nice but I don't want it to get any warmer.
    Jul 2014
    Oakbank, Canada
    389
    The clear one allows the sun to go through and heat the water, reflects he rays back into the water bouncing back and forth.
    This would have been my 4th season with it, 5 year warranty but I doubt I will get anything out of it.
    Orlando, FL
    690
    Good to know. I am going to get a new cover soon and I have been debating the clear cover. I will stick with blue because no doubt exists when the bubbles begin to fall apart.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
