Thread: CYA and SWG
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    CYA and SWG
    quick and easy question
    I've been a TFPC man for 2 years now and assisting a friend with his new pool at a recently purchased home.
    it is a SWG pool - mine is not
    He had his liner replaced in the spring and has basically done "nothing" with respect to balancing water up until now - when algae is understandably having its way with him
    My Taylor #s indcate ZERO CYA - which is what I would expect.
    As far as CYA is concerned - is it, in fact, accepted that CYA for a SWG should be between 60 and 80?
    I am happy to assist my friend, but don't want to steer him wrong in any manner.
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: CYA and SWG
    Yes, though recommended between 70 and 80 assuming his pool is outdoors. The target levels/charts can be printed for him.
    Sounds like he needs to SLAM first though. In that case keep CYA around 30 until the pool is sparkly with bleach. Then raise CYA and start SWG.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2013
    southeast
    118
    Re: CYA and SWG
    Wow - thanks for the reply
    He did add CYA to bring to right about 30 / all he purchased / and I was advising to go ahead and target the 70 mark, but, sounds like holding off makes sense for now until algae is gone
    All of the water samples I have checked show zero CCs , but, I guess this is possible, yes?
    I have advised a OCLT, but, he hasn't received his kit yet to test.
    Is a SWG pool any less likely to show CCs for some reason?
    TF-100 test kit
    Pool Tool's Avatar
    May 2014
    757
    Re: CYA and SWG
    Yes, definitely hold off on adding more CYA. He will use considerably less bleach to SLAM (the biggest draw back of a SWG pool).
    Yes, cc can show zero even when killing algae. The only time I had high cc was when clearing ammonia. It is easy to try and tie the two together; add FC, FC kills, turns into CC, repeat but the correlation is not that direct. And the cc offgasses quickly without a cover on.
    While waiting for the test kit, I would assume 30 cya and add 1 gallon of bleach per day until kit arrives. This should help not let the pool get worse, but if it is already a swamp forego that. Just have him rake to remove as much debris as he can. And start buying bleach and get ph down to 7.2 to be ready to slam.
