Results 1 to 15 of 15
Thread: Noob question, is there a recommended order of TF-100 testing?
    clutchman001's Avatar
    Jun 2015
    Meridian, MS
    22
    Good Morning all, I am eagerly awaiting the arrival of my TF-100 and K-1766, which, according to tracking, is on the truck for delivery. My question is, is there a recommended order of performing the tests? I have been using my PB's K-1766 salt test, and an aquachem kit since we put the water in the new pool last week, Salt is at 3400 ppm, and CL- 1.5 and BR- 3.4, pH was 7.8.
    Or, should I perform the tests as close to the order of the Pool Calulator as i can? I also plan on creating a binder to log my test results in so i can try to learn and keep track of how and when this beast eats.
    18x36 Vinyl Liner In-Ground, 29,200 gallon, 2 h.p. Max-E-Pro P6E6G-208L Main Pump, Zodiac Pool Systems Booster Pump, Hayward Pro Series S244T Filter, Hayward AquaRite AQR15 Chlorine Generator w/T-Cell 15, Polaris 280, TF-100 w/Speed Stir, Taylor KF-1766 Salt Test
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Noob question, is there a recommended order of TF-100 testing?
    I think you'll find most people follow the order that matches how the instructions are printed on the laminated card that comes with the TF-100. But any order will do you just fine.
    EDIT - Chlorine/Bromine. While some tests will list Bromine levels, you will not have that in your pool unless you are using that as your sanitizer in lieu of chlorine. Bromine is often used in spas and rarely in pools.
    Congrats!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    I don't use the TF-100 but I don't think there is any specific order for testing no matter what kit you use. You definitely need to know how much CYA is in the water, and well everything else so you can get a good idea of where you need to start and/or adjust. Once you get the kit, post a complete set of results and go from there. SWEET pool by the way!!
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Jul 2014
    Hope Mills, NC
    569
    I start by testing salt and temperature, as my salt meter needs to sit for about a minute. While that is running, I set up the speedstir and get the chlorine test started.
    After that, I just follow along with the instructions in order.
    I recommend the speedstir and a side dispensing sample bottle, it makes the test much easier since you don't need to keep reaching into the pool.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    30,432
    There is no particular order. I would suggest you take a water sample from about a foor down in your pool and then go inside and set at a table for your first couple of complete tests.
    After that, you will become quite comfortable with the tests and determine your own method.
    I still like to do mine indoors because it is a comfortable environment and the "cool ones" are not far away.
    Jun 2015
    Meridian, MS
    22
    Thanks Razorhog, now all the real work begins, as my yard looks like it has been shot at and missed, and sh*t at and hit!
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Quote Originally Posted by clutchman001 View Post
    I know how you feel. I do all of my own yard work too. Looks like you have a good sized John Deere in the background there. What model is it? I have an X500. Just a garden tractor but it's a beast
    Jun 2015
    N Tonawanda, NY
    476
    Keeping a log is a good idea. When the kit arrives post the results & wait for advice before adding any chemicals. Your pool looks good already, are you having any problems?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Jun 2015
    Meridian, MS
    22
    Griswald, I did order the Speed Stir as well, but what is the side dispensing bottle? duraleigh, i think that relative position to the "cool ones" sound like a plan, since the wife's Tiki Bar is not built as of yet, I will never see the end of the "honey-do" list, which is one reason why i am so anxious to at least get the pool right from the start!
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    I forgot to add - about keeping a log of results. I use an iphone app called "Pool Checks". Easy way to keep up with test results
    Jun 2015
    Meridian, MS
    22
    Mike1162, No problems yet, (knocks on wood) and want to get everything right as I can from the start, so I will not create my own downward spiral.
    Razorhog, I have an Android, so i will check the playstore, thanks for the headsup. Is it pretty simple to use and compatible with the TFP philosophy?
    Jun 2015
    N Tonawanda, NY
    476
    [QUOTE=clutchman001;860204]Mike1162, No problems yet, (knocks on wood) and want to get everything right as I can from the start, so I will not create my own downward spiral.
    No No No ! You're doing it all wrong. I'll bet more than 95% of us found this site after having problems.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Yes it's pretty simple. Shows a calendar and you click on the day to enter test results. Has a spot for FC, CC, CYA, TA and Adjusted Total Alkalinity. Wish it had a spot for CH but there is a notes section on each test that you can put stuff. When SLAMing I record the FC level, and how much bleach I'm adding to get to shock level in the notes section. It automatically records the time of day.
    Jun 2015
    Meridian, MS
    22
    I found the Simplepool app, and did a search on the forum, it looks like the developer was a member here, has anyone else used this app?
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    I've been really happy with PoolPal on Android.
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
