Thread: Free Chlorine Level
    Jul 2015
    Boston
    5
    Free Chlorine Level
    Hello all,
    New pool owner and I have adjusted all levels to within normal parameters with the exception of FC, which is reading very high at 15ppm. IS it OK to leave it at that and let it drift down normally? I have an inline chlorinator that I stock with the HTH 3" Tri-Chlor tabs and am also worried about my CYA levels creeping up, is there another alternative to the tabs that will not raise CYA? I have been toying with the adjustment level on the in line chlorinator, steadily decreasing it, now set on 3. Thanks for any suggestions.
    John
    FC 15ppm
    CC 0ppm
    PH 7.6ppm
    TA 100ppm
    CH 190ppm
    CYA 80ppm
    24k gallons, 36*18 inground pool, plaster, DE filter, I'm in Boston and pool is in direct sunlight most of the day.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,178
    Re: Free Chlorine Level
    Welcome to TFP!!
    The only option to keep the CYA down is liquid products or converting to a Salt Water Chlorine Generator.
    Yes, you can let it drift down normally, but remember with a CYA of 80 you want to target 9 and never let it go below 6.
    How did you get these numbers, your testing or pool store?
    Support the site
    Jul 2015
    Boston
    5
    My first test was at a pool store, now I'm testing with a Taylor K2006 kit. So free chlorine at 9 and not below 6? Thanks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Chlorine is set based on CYA and the Chlorine CYA Chart
