Results 1 to 11 of 11
Thread: New Build - Bad Rain Caused Collapse
    Mar 2015
    Dallas, Texas
    133
    Started our pool about two weeks ago. All was well until another big rain came through just a day before gunite. Now the walls have caved in, and the bench step in the deep end has eroded by about 50%.
    How big of a problem is this? 20150701_063712.jpg20150701_063647.jpg20150701_063627.jpg
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Build - Bad Rain Caused Collapse
    I have no idea, but that sucks... sorry
    I hope its easy to fix, what did the poolbuilder say?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    No problem at all. PBs deal with rain and erosion on lots of builds.
    Mar 2015
    Dallas, Texas
    133
    PB is suppose to be out today to evaluate the scope of the problem. What should I look for to make sure I'm not getting a patch job, but rather a fix that will not compromise the longevity of the pool?
    Jun 2015
    Phoenix, AZ
    216
    On the flip side, the more shotcrete you get, the stronger your shell is going to be . We had some erosion and they just shotcreted the whole thing. I am sure there are some sections that are at least 2.5 ft thick in my pool!
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Apr 2013
    Sacramento, CA
    2,769
    The big issue is the rebar. There should be ample clearance under the rebar for at least 2 inches of gunite. Generally you don't want a pool on compacted soil. So generally they remove the collapsed material to get the rebar clearance and just put in more gunite. My step was enlarged by 30% without soil under the enlarged portion.
    This is labor intensive to resolve for the PB, but a fairly common occurrence.
    JoyfulNoise's Avatar
    May 2015
    13,177
    Did it pass rebar inspection? If so, then the PB will have to clear the debris, fix any rebar problems and then go for a re-inspection. That would be the appropriate thing to do though I suspect some PBs, having gotten a pass, would just fix and shoot to avoid an inspection delay or a possible inspection failure.
    The biggest problem for you is that it will delay the build. Any cost to fix the damage is on the PB.
    Matt
    Mar 2015
    Dallas, Texas
    133
    PB will,be out first thing tomorrow morning to pump the water out. They assure me it will get fixed, not sure the plan yet I'll ask exactly tomorrow what they plan on doing. There is easily 2 ft or more gap on the backside where we were having a beamed wall. I'm wondering if they plan on backfill in or filling the void with extra gunite.
    Any advice on how they should fix this?
    As for the inspection the rebar passed but they did say they will have to have the inspector back out now.
    Feb 2015
    Leesburg, Va
    164
    That is a mess. We had some collapse too. The PB will recover it. We did have some issue later after the gunite in the same area of our collapse. The patio people did not back fill enough. We had two major rains and the ground sunk in the area. We are fortunate there was a delay before they laid concrete. The patio people will bring a a tamper machine to settle the soil better in the area. This is something they should have done in the first place.
    Pool build spring/summer 2015. IG. 750 sq ft pool. 40 sq.ft spa. 18ft x 42ft rectangle, 31,000 gallons, SWG, DE Pentair model, 2 boosters variable speed model, heater master temp Pentair, Quartz finish Aegean Green, CoverStar Automated Pool Cover, Kreepy Krawley Platinum, TF100,SpeedStir My Build in Progress
    Mar 2015
    Dallas, Texas
    133
    Quote Originally Posted by poolnorthernva View Post
    So overall do you feel the collapse effected or will effect the quality of your build long term? Do you know what they did to fix your collapse?
    Feb 2015
    Leesburg, Va
    164
    Quote Originally Posted by daveooph View Post
    We are still in the final stages. I don't think we were hit as hard as you. But it is just dirt. After they put up the gunite there was a large hole that needed to be backfilled. This COULD have been a problem if they laid the patio the day after the surface was smoothed. But we discovered the soil compression (from not enough fill dirt back filled in) and the will remediate it before pouring concrete over the area. As for the pool structure, they had to add some extra wood forms to hold things in place but not much else.
