Results 1 to 7 of 7
Thread: Ready to start testing with my newly arrived TF-100 kit
    Jun 2015
    Concord, CA
    5
    I finally received the kit but before I start I have a few questions.
    I was away on vacation for a week and noticed green algae. I dropped some shock last night and let the pump run on high for about 5 hours. The water appears cleaner. I then decided to do my monthly filter cleaning and it was very green. I rinsed it till all the green was gone and the entire filter assembly. I decided to drop another shock treatment to ensure I got all the algae. Brushed the entire pool to make sure the green cloud from brushing was gone.
    When should I start testing with the kit since I just shocked?
    Also, I am using chlorine tablets but all of my reading on this forum suggests to not use it since it lowers PH. Is the alternative to use household bleach or liquid chlorine?
    What are people using to raise PH? (Borax or Soda Ash)
    My Pool = 17,300 gal, Plaster IGP, built approx 2008, Cartridge filter, Jandy Pump 2 speed, TF-100 test kit, Dolphin Triton robot cleaner, my city is on water restriction.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Ready to start testing with my newly arrived TF-100 kit
    Good news first...you got the test kit! woohoo!
    bad news...stop adding powder shock and/or chlorine tabs. lowering of pH is not why they are not recommended, its because they add CYA to your pool...and very quickly. im worried you are going to have very high CYA.
    test your pool asap and post full results here, and we will help you get this fixed.
    TFT method involves using only bleach/chlorine (same thing) or using a saltwater generator. either way, its chlorine.
    but no more powder or pucks, ok!
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Concord, CA
    5
    Did the test this evening and the numbers are:
    PH - 6.8
    FC - 8
    TC - 8.5
    CH - 850
    TA - 130
    CYA - 100+ (could no longer see the black dot before the first line of 100)
    Thanks for your help.
    30,421
    Welcome to the forum.
    "Yuck!" on your test results. Your first order of business would be to reduce your CYA and CH. That can only be done by a partial drain and refill. Let's stop right there because you are in California. Will regulations allow you to drain at least half your pool? There is really no other way to Get your CYA and CH down.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    yuck indeed. CYA and water restrictions are a bad thing
    Dan
    Jun 2015
    Concord, CA
    5
    I have read the option of reverse osmosis. Not knowing the cost, will RO help?
    Aug 2013
    Arab, Alabama
    422
    Yes, RO will help...but I believe it can be expensive.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
