Results 1 to 9 of 9
Thread: Pump tripping breaker
    Jul 2015
    Greenville/SC
    3
    Hello. Could someone help with some knowledge? I had my pump replaced because it was leaking. Upon installing the new Hayward Super Pump 1hp the breaker would trip. The pool professional said to have an electrician check. I hired an electrician and they checked it out and said everything was good it had to be the pump. I told the pool professional that and they suggested using their own electrician so I did that and he also said everything was good and it had to be the motor. So the pool professional came out today with a brand new motor yet again and it did the same thing. No one apparently can help or knows what is going on? Anyone have any ideas?
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump tripping breaker
    Welcome to TFP!
    Is it on a 120V or 240V circuit?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    what is the exact pump? Is it a GFCI breaker, there have been some issues with VS pumps lately and GFCI..
    Jun 2015
    Wildomar, California
    423
    Yes, is your pool circuit 110v or 220v? These days most major manufacturers have their motors set at 220v. A common 1hp motor can be set at 110v or 220v. It's posted on the motor.
    Jul 2015
    Greenville/SC
    3
    Thanks everyone. It is 220v. Neither the pool person or electrician can figure it out.
    SW Indiana
    9,199
    Quote Originally Posted by blueajax View Post
    Is the circuit 220, or the pump? The pump can be wired either way. You have to move wires inside the cover to select your operating voltage.
    Jul 2015
    Greenville/SC
    3
    Thanks John. The pump is 220 or 110. The circuit is 220. The power going to the pump is the same voltage as the pump requires. I suppose that's why no one can figure it out.
    If you're looking for good answers it's best to provide as much information as possible.
    Remember, no one here has seen your set up, so it's pretty much impossible to diagnose anything with the information you've given.
    Pictures would be great.
    Show the electrical connections to the breaker, the switch and inside the pump.
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Jun 2012
    western NY
    1,562
    Can you provide the model # of the pump? This will help us immensely in trying to figure out what is going on. For example, VS pumps have been known to have issues with GFCI breakers.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
