Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Pool Solar Finished
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Pool Solar Finished
    Well finished installing 7 Fafco 4 x 10 solar panels, I picked up 11 of them for 50.00. Then decided to paint the house..Thanks to the supporters of this site...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Pool Solar Finished
    50 total??? wow!
    Looks great.
    Free heating is fun!! I only have to use mine every other weekend or it gets too warm.
    Dolphin E10 Cleaning Robot.
    38,415
    Wow! I paid about $50 for each panel which I thought was a great deal. Looks great.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Sweet! Here's to warm pools!
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I have 4 left over, I would like to store them, but I live in a gated community. I was thinking just secure them on an unused roof section. Then if I need one it's there...
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thank you for your help...
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I wonder how much heat I am losing by painting them, anyone know...
    Autopilot SWG
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    oh haha I thought they came that color for some reason.
    Not sure but I know black absorbs heat best.
    do you have temp guages on your plumbing to indicate incoming and outgoing?
    I have black Solar Industries panels and they add anywhere from 4-8 degrees usually.
    Oct 2014
    Bay Area, California
    146
    You should cut a couple pieces of pvc, like 1 foot long each and paint one the tan color and one black. Then you can either use an infrared temp gun or just feel by hand.
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    A lot is going to depend on the type of paint that was used, as the infrared emissivity may be completely different than the visible color. If you used something like Krylon standard spray paint the emissivity of it will be very high (.96 or so) making it good absorber of infrared heat. Of course the lighter visible color will cause some heat rejection either way, but the IR emissivity will be a big factor.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If I flip them over to the unpainted side, having the bottom painted shouldn't have any effect on the heat it puts out, or will it?
    Autopilot SWG
    38,415
    I would think it would be negligible since it is not really exposed much to the sun anyway.
    Jun 2015
    Ottawa/Ontario
    340
    You probably should not have painted them if you wanted to maximize solar gain....but i would only see that as an issue if the solar was your sole heat source. Of course the beauty of it is that if you find they are not pre heating enough for your liking, you can simply paint them black (again).... #solarmakesiteasy
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Where can I find solar panels for $50 a pop!?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Lunarpancake View Post
    If you figure that out, put me down for 8-10 of them.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2015
    Ottawa/Ontario
    340
    Same!
    Jun 2015
    Ottawa/Ontario
    340
    Just to be clear - they aren't solar panels, they are active solar hot water tubes.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Pool Solar Finished
    Quote Originally Posted by tlevy View Post
    That's a pool solar panel. We just call them solar panels. Not to be confused with photovoltaic solar panels. The fafco ones like you got usually run $160-190 each, so you bought $1800+ worth of panels for $50. We all kinda hate you right now. Well, we're envious anyway.
    Jun 2015
    Ottawa/Ontario
    340
    Fair enough. I am a solar PV guy, hence my anal retentiveness on this one! Haha
  20. Back To Top    #20
    38,415
    I got mine used off of Craigslist.
