Thread: Intex pump hoses
    Jun 2015
    Mount Plesant, SC
    23
    Intex pump hoses
    Amazon.com: Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 110-120 Volt with GFCI, 2100 Gallon: Patio, Lawn Garden
    Will the screw on hoses that come with the intex pumps like above fit on standard 1 1/2 inch ends if you use a hose clamp. The manuals on intex's site say they will, but I have seen several things about using adapters or chainging the inlets out for intex inlets when adding the pumps to non intex pools. But, if you have 1 1/2 inch connections I don't see why you need an adapter or new inlet, excluding the summer escapes skimmer adapter. Also, do all the Intex sand pumps use 1 1/2 inch pipes? I think they do, but I don't want to buy one and find out I was wrong. Thanks.
    Summer Escapes 15ft x 42in.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intex pump hoses
    They will screw onto 1.5" fittings. If you have a 1" fitting you need adapters or change your fittings to 1.5"
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    Mount Plesant, SC
    23
    My fitting are 1.5" I am using a 1.5" hose now from the inlet to the summer escapes pump. But, these are not scew on fittings. It just uses normal hose clamps. Does the screw on collar of the intex hoses just slide back and allow you to use it as a normal hose with a hose clamp? The online manually seems to suggest that, but I have never seen a picture of it done.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You can slide the nut back and just use a hose clamp. You cannot remove the nut from the hose though. Your other option would be to check the pool dept at Lowes and Home Depot to see if they have any pool hose without the nuts.
    Just popped into my head, but it will only fit flush with the end of your connection. You would have to find a hose slightly larger to go over where you want to connect it to so you could clamp it.
    Lisa
    Jun 2015
    Mount Plesant, SC
    23
    Quote Originally Posted by Azgirl71 View Post
    So, an Intex hose won't go over the same size pipe that any other 1.5" hose will go over? Or, are you saying a normal 1.5" inch hose won't go over the connection on the intex sand pump and that would need an adapter, which I know they have on amazon? I am really only interesting in if the intex hose will slide over and clamp to a pipe that a normal 1.5" inch hose would work on.
