Results 1 to 8 of 8
Thread: Oil Spill
    Jul 2015
    dedham
    1
    Oil Spill
    Hi,
    This is my first time here and the search wasn't working properly... kept sending me back to google.
    Anyway, we are first time pool owners and made a few mistakes, the last one being a huge one and the only person I can point a finger at is me. Background: Coleman above- ground 16ft round 48 inches high pool. Even after all the leveling we did, once filled the pool sank almost 3 inches on one side. We decided to drain it. The hose worked great for 60% of it, but we decided to use a sump to get the rest out. I dropped the sump pump and it cracked. I didn't see it and put the pump in the pool. quickly realizing there was a oil leak I took the pump out. There is about 6 inches of water in the pool and a small shimmer where the pump oil is. What can I do? Desperate for help.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Oil Spill
    Welcome to TFP. When you use the search box it does take you to google, but all the links are linked back to TFP.
    I do not have a answer as far a clearing the oil. If it is floating on the surface, I imagine you might be able to take a bucket and skim the surface to get some out.
    I am sure someone will be along shortly with other suggestions.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Oil Spill
    This stuff. Enzymes will eat the oil. Pool First Aid | Product Detail | Natural Chemistry
    Jun 2014
    14,970
    Re: Oil Spill
    If there's only about 6 inches remaining, maybe just get another pump and empty the rest of it out? Cut your losses with water as opposed to trying to filter it out or find other tricks for removal. Hard to tell without actually knowing how much oil is in the water.
    Enzymes! Gotta remember that one.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Oil Spill
    For larger spills, there's also PIGŪ Absorbent Mat Pad (or PIGŪ Oil-Only Absorbent Mat Pad if you're sure it's oil).
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Oil Spill
    Quote Originally Posted by chem geek View Post
    I have an entire box of these and I LOVE THEM!! I used them over the course of a week when my brother and sister-in-law came to visit. My SIL was big into the tanning oil and would grease herself up, then dive in the pool when she got hot and then grease herself again. The PIG Mats worked great at sucking up the oil on the surface (I cut one up and put it in the skimmer to keep the oil from getting into my filter).
    Be careful to get the right P/N though. They have mats that absorb water-only and oil-only and it's not always obvious from the title description.
    Matt
    Re: Oil Spill
    Submersible pumps are usually filled with non-toxic mineral oil. You can contact the manufacturer to inquire about the specific pump.
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Oil Spill
    Quote Originally Posted by JamesW View Post
    That's interesting. I didn't realize they had any oil in them at all. I assumed, obviously incorrectly, that they were magnetic drive pumps like pond and fountain pumps. I just looked up the manual on mine and it lists and oil fill plug as a replacement part. Learned something new today.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
