Results 1 to 10 of 10
Thread: normal for an intex?
    Jun 2014
    texas
    6
    Good afternoon,
    I have a intex 22' x 54" pool and 2 of the legs are not completely flush with the bottom of the pool. The pic is located below. The pool water is level within 1".
    I'm a paranoid ocd type. Is this a hazard or is this normal?
    20mb image hosting
    Thanks
    Matt
    Jul 2014
    Oakbank, Canada
    389
    Re: normal for an intex?
    Be nice if they were straight, but they will be okay. They are pretty much as far out as they are going to be now.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2012
    MA
    347
    Totally normal. My Intex 20'-52" came with a rope around the bottom of the legs.
    Jul 2014
    Oakbank, Canada
    389
    Mine did too, I would suggest putting a 1/2" rope around the bottom just to be safe side.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    That looks fine, but I agree with adding a rope just as a precaution, as shown here.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    VB,VA
    13
    I am constantly adjusting mine, though I will admit I did not pay close enough attention to them as I filled the pool. Most of mine were off a bit. Next year I will be more careful to make sure as the pool fills that I monitor the legs and feet positioning. I put mine up on a concrete slab, so its easy to move them by pushing up on the top rail.
    Intex 14x42 Ultra Frame with SWG and Sand Filter
    Jun 2014
    texas
    6
    Thank you everyone for the feedback!
    Regarding the rope, I can add that, but I don't think that my pool has the loops.
    I shouldn't try to pull the leg in more with the rope correct? My objective is to make it tight enough so it stays put?
    May 2012
    Las Vegas, NV
    92
    use tie down ratchet, you can find them at harbor freight tools
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    Mine isn't really even tight. I think it's just a safety feature to keep the legs from giving way should the vinyl belt holding them break.
    Pentair IC40 SWG
    Jun 2014
    texas
    6
    More advice needed. One leg is pretty much off the paver. The plastic footing to partially on the paver, but the part were the leg comes down is not. The paver is too far in towards the pool. It doesn't appear to be causing issues with the liner.
    The leg has not sunk at all. Its level, but it's the only one not on a paver. I'm more concerned that the plastic footing is against the paver, because I'm fearful it will break and cause sudden drop of it were to get really muddy.
    The more I think about it though, if the other legs stay firm and this one does slip off the paver wouldn't they almost hold it up enough? Not ideal, but I just got the water right and wanted some opinions before I drain it.
    It's a ultra frame 22'. It sounds like it's not a good idea to jack up an ultra frame.
