Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Sand Filter/NEW pool Owner
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    Question Sand Filter/NEW pool Owner
    Hi all. I NEED HELP!!! I inherited a pool with a house I purchased. I've been trying to get it up and going myself and this is proving to be an impossible task. First the water is pretty much BLACK (I'm told that is black algae (sp)) I was told to pour algaecide (sp) and let the water "circulate". The only problem is that the filter system was not covered and the settings on the arm have been faded by the sun and it seems to be an older sand system and I cannot locate what the settings should be.
    I would love some help. As I said I'm totally new to this. Cannot afford the "professionals" and I've asked a few installers that do this on the side for help they have made many appointments and never showed up nor called. It is very frustrating . I wanted to have a 4th party but that isn't going to happen. I'm in Tulsa, OK.
    Any help with be helpful!!!
    thank you to whomever started this forum
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand Filter/NEW pool Owner
    You were told wrong about the algaecide. It won't help, and may hurt. What you need is chlorine.
    You need to get things running first so you have circulation. Rinse, waste and backwash will result in water coming out of the clear fitting on the filter. Recirculate and filter will move water from the skimmer to the pool return. On closed, water won't go anywhere. If your pressure gauge works, you'll probably be able to narrow down which is which. If it doesn't work, get a new one.
    Check out the article Defeating Algae for more information
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    thank you yippee $21.95 for something that could possibly cause more damage. I went and purchased a new gauge and that helped. It is now on circulate and doing so. I have to purchase a new scrub brush and then I will start the waste and backwash today after work. I've read a couple threads on here do you recommend BLEACH and use that? My pool is 30 ft round 4 1/2foot deep I tried changing my signature with as much info as I had.
    thank you for a least getting me started somewhere.
    Quote Originally Posted by JohnT View Post
    30,000 gallon 4 1/2 foot
    Sand Filter
    Above Ground -Circle
    Hayward Motor
    Millennium Ultimate Granular Filtration System
    Aug 2014
    Northern IL
    4,615
    What is the diameter of your pool? Is the water depth 4-1/2 feet or is that the wall measurement?
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    All I do know is that it is a round pool measuring 30ft and I believe the wall height is 41/2
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    Okay. I calculate 23,800 for 4-1/2 foot WATER depth, 21,100 for 4 feet of water. Your signature says 30,000 and I wanted to make sure you didn't use that incorrect volume to calculate any additions!
    And yes, use bleach!!!
    Sorry it took me so long to respond. TFP has been weirding out today for me.
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    No I didn't use those calculation I will change that I'm sorry I'm not sure how to calculate this.
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    NO need to apologize!!!
    The reason I wanted to clarify your volume is because with a 30,000 gallon pool, 1 gallon of 8.25% bleach would increase your FC by about 2.7ppm. With a 21,100 gallon pool, 1 gallon of 8.25% bleach would increase your FC by 4.0ppm. That is a significant difference, especially during a slam.
    If you are curious how I came up with your volume, here's how. A cubic foot of water contains 7.48 gallons. The volume of a round pool is (pi x radius squared x depth) cubic feet. 7.48gal/cu ft x pool cu ft= pool volume in gallons.
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    Thank you so much. I'm sure I will have more questions tomorrow thx again
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    Did you figure out your multi-port positions? Filter, recirculate, rinse, backwash, waste, winter/closed? We can be more specific about those if you need more help. Record them on a piece of paper until you're positive of which is which. Then mark them with a sharpie for future reference.
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    I went to a pool store who had one like.mine up and running took a picture of it and it matched. I bought a new gauge as well. Now I am circulating the water. Is that correct with one Gal of bleach?
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    Now that you have your mechanics running, it's time to start talking about testing methods. At TFP, pool store test results are not trusted. We really can only help with pool chemistry if you purchase a reliable test kit.
    I use the Taylor K-2006C. Many on the forum use a hybrid version of the Taylor kit called the TF-100. Either way you go, you need one of these kits. It's an outlay of $70 bucks or more, (prices vary with time), but it will pay for itself over and over again. Just think if you had bought 3 bottles of useless algaecide from your store. Kit paid for!
    Here is TFP's link about test kits: Pool School - Test Kits Compared
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    Ok I don't have a test kit I will need to get one tomorrow and then get back on here.
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    Great! Don't buy one at the pool store unless they have a FAS-DPD test. Only maybe 1% of pool stores nationwide sell them. (It would hurt their business...) You probably have to get it online. If you are in a hurry, go with the fastest delivery date!
    If your pool water is black, it will take a while to fix. While you're waiting for your kit, check liquid chlorine/bleach prices at every store you go to. (Big box hardware, Aldi, Walmart, etc.) Look for two things.
    1) % strength. The strength should be listed on the bottle. If not, you don't want it. Make a note of %, bottle size (ounces), and cost. You can calculate effective cost that way. Don't get too bogged down by the math if it's not your thing. 1 gallon of 6% at $2.99 is not as good a deal as 1 gallon of 12.5% at $3.99.
    2) Look for a code on the box or bottle. It may have a "bottled on" date, or it may have a 5 digit code like 15142 which would be the 142nd day of 2015. Chlorine loses it's strength over time or when exposed to heat/sunlight.
    You want the freshest, and least cost per effective ounce you can get.
    Hope that wasn't too much info...
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    Not at all informative for sure. I will order my test kit. So what besides looking for chlorine /bleach should I just let the water circulate while I'm waiting for my test kit?
    Sand Filter
    Hayward Motor
    Aug 2014
    Northern IL
    4,615
    One thing you can do now is add 64 oz of bleach every night to add 2ppm FC. You don't want too add too much because you could damage your liner since we don't know what your CYA level is.
    Continue brushing the pool and getting out any debris.
    Another is to do lots of reading in Pool School (above). Read especially:
    Pool School - Chlorine / CYA Chart
    Pool School - SLAM - Shock Level And Maintain
    Pool School - PoolMath
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    You want your multiport valve set to "Filter". Circulate (or recirculate, however it may be labeled) bypasses the filter and just dumps the dirty water back into the pool.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    Thank both of you I will get the bleach, brush it and it is on circulate.
    Sand Filter
    Hayward Motor
    Meinyon's Avatar
    Jul 2015
    Tulsa, OK
    17
    So I started seeing the algae float and i.coyld see my stairs now it's raining in Oklahoma. Is this going to hurt my 24 hour progess really bad
    Sand Filter
    Hayward Motor
  20. Back To Top    #20
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    No, rain really doesn't affect your water chemistry much.
    Pentair IC40 SWG
