Results 1 to 7 of 7
Thread: Replaster Question
    Replaster Question
    So our pool is around 15 years old and I am starting to see copper marks on the bottom of the pool and a few baseball size indentations in a few areas of the concrete. Would acid washing fix this ( We never acid washed) or do you think a full re-plaster is necessary. Also, what would re -plastering cost in general if we wanted to do pebble tec our pool is roughly 20 x 44.
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Replaster Question
    Acid wash might clean some up, but where is the copper coming from? PT is just one option, but I would plan on 10-12 K as a starting point for that pool depending on what color. Upgrades to darker Blues might shock you in pricing. I would suggest quartz over PT, but that's up to you of course.
    Essential Links:
    Quote Originally Posted by Patrick_B View Post
    Thank you, whats the main advantage of Quartz over pebble tec?
    Bel Air, MD 21015
    Apr 2013
    Sacramento, CA
    2,769
    The copper might not be copper but rust from rebar showing through the pool.
    The big difference is feel -- remember Pebble Tec has other finishes that are not as rough. But you usually pay a premium for the brand name. There are plenty of other premium finishes that you might like.
    You are in Maryland -- I wouldn't be surprised if prices are steep but I would call 3 or 4 plasterers and get bids.
    We just had a full replaster (sandblast down to gunite and full resurface. We ended up with regular marble plaster. The 10-12K is a fair estimate for pebble tec.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jun 2015
    Atlanta, GA
    640
    Hi Geebot - what was the price difference between replastering and Pebble Tec?
    12K Gallon IG Lap Pool (c. 2001)
    6.6 ft x 48 ft/White Plaster/Concrete
    Pentair Superflo VS Pump 2.0 HP/Sand Filter
    Dolphin S300i Robot/SolarBreeze Robot
    TFT-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Pebble finishes have tiny, tiny rounded stones as the aggregate, where Quartz has crushed sand like particles of Quartz as the aggregate. It's much smoother, and just about as long lasting and durable as pebble. Pebble is expected to last longer as a rule, but it's a very personal choice based on what feel and look you prefer. Expect pebble finishes to be double and up over plain plaster with Quartz being in between. Properly cared for and installed well, even plain plaster can last a very long time.
    Copper stains differ from rebar stains as those are brownish/orange-ish type stains where copper is generally blue ish/greenish in color.
    Essential Links:
