Thread: Intex SWG troubles
    Northern NY
    61
    Intex SWG troubles
    We've had an intex SWG with great results for the past 3 years or so. This year ours wasn't working and I ordered a new one off amazon. So far it doesn't seem to be working and I'm not sure if it's this particular SWG or something diff with the new ones they are making. I ran it yesterday for 10 hrs and only have .5 chlorine levels. The pool is clear with no signs of algae and we've had the cover on the whole time. The old one I used to run for 3-4 hrs and would have no problems keeping chlorine leveled where they should be.
    This is the model we just bought.
    Amazon.com : Intex Krystal Clear Saltwater System (Discontinued by Manufacturer) : Swimming Pool Chlorine Alternatives : Patio, Lawn Garden
    We are leaving for a camping trip now but my plan is to return it after we get back but wanted to check here for help first.
    Thanks
    24' AG - Built July 06
    Sand filter
    SWG
    2 - 2x20 Solar panels
    Can't wait for the warm weather!!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intex SWG troubles
    Was your FC already up where it should be prior to running the SWG?
    The reason I ask is the SWG won't bring your level up to where it should be. However, it will help maintain it if it is already up.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Clear water does not always mean no algae. If your pool spent some time with FC below minimum level there could definitely be algae in the pool and the SWG will not be able to keep up with it. My pool has been perfectly clear for 3 years and I had algae a few weeks ago that took a week to SLAm and the water stayed clear the whole time.
    Raise FC up to 10 ppm with bleach, turn off the SWG and Pool School - Perform the Overnight FC Loss Test (OCLT) to see if there is organic matter in the pool consuming FC.
