Thread: Going Out of Town SLAM Question
    Aug 2013
    South Louisiana
    41
    I'll be heading out of town for two days and won't have help with the pool. I've read on here some raise the FC to SLAM level for this short of a trip and let the FC level drift down, which works perfect in this instance. Do I have to let the pump run continuously like a SLAM for algae or can I leave it on the timer like usual? Just wondering if the water sitting still at a high FC level will damage the liner or pool equipment.
    Thanks
    18'x54" Round AGP, 7,600 Gallons
    150 sq ft Cartridge Filter, 2-speed 2hp pump (Hard Plumbed)
    TFPC Method
    TF-100 Test Kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,462
    Re: Going Out of Town SLAM Question
    Just make sure your pump ran long enough to really mix the FC and you will be find leaving it like normal.
    Kim
    Aug 2013
    South Louisiana
    41
    Great, thanks for the response.
    TFPC Method
    TF-100 Test Kit
