Results 1 to 10 of 10
Thread: PoolMath ....Iphone app?
    Jun 2015
    Glendale, AZ
    156
    I have been using Poolcalculator looks to be the same as PoolMath? Does it make any difference?
    Do any of these have an app for a Iphone? I found (PoolCalc - The Pool Calculator) which looks like it may be the ticket.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: PoolMath ....Iphone app?
    I'm not 100% sure, but I don't think that pool calc is updated anymore and poolmath has more current updates. I use Poolmath in a browser on my phone and tablet.
    38,275
    PoolMath has some updates, so I would recommend using it instead.
    Jun 2015
    Glendale, AZ
    156
    Thanks guys I will use PoolMath...
    As a side note, I saved the webpage PoolMath to my Iphone home page and looks to work ok. The 'Now' inputs do not save, but both 'Now & Taget' save to the Target numbers...
    Mar 2015
    Harvey, LA
    300
    I use poolmath most of the time, but as recent events can show, there's definitely value in having an app, since it works when TFP (or the internet in general) is down.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    38,275
    Or just save the PoolMath page locally on your computer ... remember those things ... they are like bigger than your phone and have a separate keyboard and monitor and sit on your desk
    JoyfulNoise's Avatar
    May 2015
    13,199
    Yup got one of those. It works great as a coffee cup holder too....now all I need is a long enough extension cord so I can drag the boat-anchor out by the pool
    Matt
    38,275
    Just make sure it is plugged into a GFCI outlet if you take it to the pool
    Mar 2015
    Harvey, LA
    300
    If I save the page, will the formulas going on in the background come with it? I don't know what language it's coded in, some require back-end comms every time there's a calculation to make, making saving the page useless if TFP is down.
    38,275
    Yes the code will be saved with the page.
