Results 1 to 10 of 10
Thread: Brown spots on floor of shallow end following seam
    Apr 2015
    North Huntingdon PA
    6
    What is the brown spot? looks like it is growing but all chemicals OK. I think we have some water under liner. Shallow is concrete bottom. Is it possible for mold to grow through the liner?
    Grod 36,000 gal Vinyl w/pentair DE filter w/1 1/2 HP pump 120GPM
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Brown spots on floor of shallow end following seam
    Can you brush it? Is it hard or soft? Fuzzy? Dark brown? Light brown? How about a pic?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Please put your pool specs on your signature. How does it react to brushing? If it plumes into a little cloud when swept and returns to the same spot It's probably algae. Also what are your water numbers
    FC
    CC
    CYA
    PH
    TA
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Apr 2015
    North Huntingdon PA
    6
    Light brown and can not be brushed.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Can you post a picture
    Apr 2015
    North Huntingdon PA
    6
    Fc 5
    cc 0
    cya 150
    ph 7.4
    Apr 2015
    North Huntingdon PA
    6
    I put a 3" puck on spots and they faded away.
    DFW, TX
    24,497
    Ok, time to SLAM - Shock Level And Maintain the pool and brush regularly. If you want to keep the FC level a little below shock level so you can keep swimming that is fine. I did and it is much easier and cooler for me to brush when in the pool.
    DFW, TX
    24,497
    Oops, just noticed that CYA is 150. That is going to take a LOT of bleach. With 150 cya you should keep FC at 18 at all times and never let it drop below 11 to keep the pool sanitized and algae free. Shock level is 59 ppm. It will take 24 bottles of 8.25% bleach to take 36k gallons from 5ppm FC to 59ppm FC.
    The best bet would be about a 50% drain and refill.
    Apr 2015
    North Huntingdon PA
    6
    I did drain about 2 foot of water and dropped my CYA down to 110. Should I slam at this point?
