Results 1 to 7 of 7
Thread: Alternative approaches to conversion
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Not to push a product, but FLIP OUT can be helpful.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Re: How to convert a Baquacil pool to chlorine
    Have you actually tried it? I can't find what it actually contains, but the directions are very similar to another product that contained bromine and has had fairly poor results in all of the cases of people actually trying it that I have heard of.
    Guest
    This is the same company that makes EZ-Pool, an 'alternative sanitizer' or, as they say on their website, a long lasting oxidizer and dry acid mixture with a clarifier. My guess is that EZ-Pool is just sodium percarbonate and dry acid. Sodium percarbonate was used as a non chlorine shock in the commercial sector but since it interferes with ORP and destroys FC by liberating H2O2 it fell out of favor. The only sodium percarbonate product labeled as such that I currently know of is Proteam System Support for clearing badly fouled pools. (It works well, btw!)
    Sodium Percarbonate IS effective at oxidizing biguanide and converting a biguanide pool to chlorine fairly quickly, btw.
    However, the description of this product's usage is more consistent with a bromine based product for converting from biguanide, much like GLB X-Change.
    http://www.glbpoolspa.com/TechDataInfo. ... ductID=136
    I tend to shy away from any company that does not make their MSDSs readily available.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Bioguard makes (made?) this biguanide absorbing product that is just carbon that you place in a skimmer sock.
    The one bucket of it that we had in my store years ago is probably still sitting on the shelf. Anybody ever use it? I remember hearing at the time that it takes weeks to work.
    Guest
    Bottom line, there is NO fast and easy way to convert from biguanide back to chlorine. You have to oxidize the biguanide and then change the filter media and the process takes some time. A large dose or two of sodium percarbonate followed b maintaining shock levels of chlorine until there is no CC seems to be the fastest but just using chlorine seems to be the most cost effective.
    budster's Avatar
    Dec 2008
    272
    Quote Originally Posted by waterbear
    I will agree, waterbear. The "rainbow effect" during the "just add chlorine" conversion method at least shows that it is
    happening!
    BTW, I have only two customers who used the Flip Out, and they reported that the conversion was "faster". I am not a big fan of that company's full line, but have had good reports on Flip Out and Revive!.
    Guest
    Quote Originally Posted by budster
    Revive is basically just an alum based floc as per the company's website stating that it "Contains Aluminum Poly-Chlorides and other natural minerals...." (Possibly some Lanthanum chloride also for better phosphate removal.)
    http://www.apiwater.com/poolowners-revive.html
