Results 1 to 9 of 9
Thread: Foam Bottom questions
    Jun 2015
    Massillon, OH
    13
    Hi All,
    I purchased a intex 16 x 32 Ultra Frame pool, and it sounds like the 4 x 8 sheets of pink foam would make the best bottom...
    Menards has 1" tonge and groove for $ 16 a sheet. I believe I need 16 sheets of it... ( $ 315 with tax and gorrilla tape ouch! )
    Question 1:
    Is the 1" thick enough?
    Question 2:
    If so is $ 16 a sheet what most of you are paying or where can I buy cheaper?
    Question 3:
    I have topsoil here in ohio and was going to just rake out the top soil as smooth as possible then I was thinking about putting a cheap tarp over the dirt before the foam.
    Do you guys put the foam right on the top soil or a tarp in between the dirt and the foam?
    Thanks for any input!
    Joe
    Jun 2014
    Fountain Hills, AZ
    32
    Re: Foam Bottom questions
    We put up a 22' Intex this year with the foam. Our last pool, we didn't have it. What a huge difference!
    Planned to use the 3/4" foam but lucked out when Home Depot didn't have enough sheets in stock. They
    Sold us 1 1/2" for the price of 3/4. Sweet at $15 per sheet. We put it directly on dirt.
    Diana
    Intex AG 22' x 52" Ultra frame, Intex 2650 pump, sand filter and SWG
    Hayward in-wall skimmer, Wanda the Whale, center fountain, Intex magnetic light
    May 2012
    Las Vegas, NV
    92
    how many sheets did you have to buy for a 22' intex?
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jun 2014
    Fountain Hills, AZ
    32
    We bought 16 sheets but had the equivalent of at least two full sheets left over. We could have done it with 14.
    Diana
    Jul 2014
    Oakbank, Canada
    389
    I used 1", and its plenty. Just love the feeling on the feet.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2015
    Massillon, OH
    13
    Darrel,
    Did you put the gorrilla pad under the foam or on top of the foam?
    Joe
    Jul 2014
    Oakbank, Canada
    389
    Under the foam so nothing grows through it.
    May 2014
    LA, USA
    16
    Used the 3/4" extruded foam sheets from Lowes around $15/sheet. For 16'x32' pool I needed 16 sheets. Worth the price!
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    I used the foam as well, in my signature is my pool build with allot of photos. The pink stuff is not available in my area so I used the white stuff.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
