Results 1 to 7 of 7
Thread: Recommended Targets for PoolMath?
    Jun 2015
    Terry, MS
    6
    I am new to the site and have been poking around for a minute or two now and have a question regarding the "PoolMath" tool. I have an 18' x 36' vinyl pool and am attempting to determine the correct "target" values that I should be using in the tool. I was looking around the site for a chart/table that had volume size and target values for vinyl pools but was unable to find one. If this table exists a link would be awesome; if not, any suggestions would be greatly appreciated.
    Size: 26,000; IG, Vinyl; Sand; Age: >5 yrs
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Recommended Targets for PoolMath?
    Welcome to TFP!!
    Well, the recommendations are in Pool School under Handy Reference, Recommended Levels
    You will get the feel for the site and how to find information with a little practice.
    Support the site
    Jun 2015
    Terry, MS
    6
    Ahhhaa, knew it had to exist somewhere. Thanks.
    May 2015
    Chickasha, OK
    184
    Also...
    In the last row of the table on PoolMath (yellow) is 'Suggested Goal Levels'. Select which goal levels you want to use (TroubleFreePool.com is obviously recommended...), your primary source of chlorine, and pool surface.
    This will change the 'Goal' numbers above the input boxes for each row. It will not, however, change the inputs. It keeps track of your 'Now' numbers and changes the goals accordingly. For example, if you change your 'Now' CYA from 40 to 30, the FC goals will change.
    Pretty nifty tool, this PoolMath. If only it could be made into an iPhone app...
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I have no issues using Poolmath in a browser on my my phone and on my Tab. Androids though.
    Jan 2014
    Buckeye AZ
    807
    Make sure to select at the bottom Troublefree site as the source of the recommendations, it will recalc all the goals. Then when you enter your pool volume, with no commas, in the field at the top for pool size, it will recalc the dosage needed to get from your current levels to those goal levels.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2013
    Fallsburg, NY
    258
    I use Pool Pal on Android, you have to manually enter your goals initially, and it doesn't do the Effect of adding chemicals section, but other than that it works great.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
