Thread: Which is the right choice?
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    I was about to order some chemical refills from TFTestkits.com but I now see three options and am confused which I need since I'm not ta the house where my kit is.
    I need the chemical you put in after the DPD powder when testing for your FC levels (to get it to turn from red to clear). I thought it was the 0871 but I now am confused between the titrating reagent and the reagent since they are both 871....
    a little help here.
    They are the 0871 bottles at the bottom of this page TFTestkits.net
    Polar Pools, 19' x 39' Vinyl Lined IG, 3' to 9' deep, 33,300 Gallons?
    Pentair Intelliflo VS, Hayward Sand Filter Model # S244T, Compupool SWG, Heliocol Solar Heating
    K-2006 test kit, 1766 Salt Test Kit , Taylor SpeedStir
    Built in 2009, Salt Lake City, UT.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Which is the right choice?
    From what I can tell is that the larger bottle will not fit in the k2006 test kit box is the only difference.
    If you open the larger bottle link it will tell you it can be used to refill your smaller bottle
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
