Results 1 to 10 of 10
Thread: Does High FC Throw Off pH Numbers?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    So, I decided to do a SLAM since it seems like I have algae creeping back every time I think it's gone. Since the other day when I ran the auto cleaner to get rid of what I thought was dirt/pollen on the entire surface of the pool, my deep end is now green. I really thought I had this beat, but I guess not. Anyway, I've raised my FC up to my shock level of 24, and it's holding right now. Just for kicks, I checked the pH, and it was at least 8.2. Is that just because of the shock level? Or do I have a bigger problem?
    FC 24
    CC .5
    CYA 60
    pH 8.2
    CH 200
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    38,507
    Re: Does High FC Throw Off pH Numbers?
    Yes. The pH test is not accurate (reads a false high) when the FC > 10ppm.
    This is why the first step of the SLAM process is to lower the pH to 7.2-7.4
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Thanks, Jason. So here's an odd question..I'm doing the SLAM, maintaining the 24 FC right now. I've been brushing the cr*p out of the pool, but I can't reach the middle of the bottom of the deep end with my brush. I'd say there's a a good 18 inch perimeter around the bottom drain that I can't reach. Is that going to cause the SLAM not to work?
    Wendy
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    It could make the SLAM take longer and/or use more chlorine. Brushing exposes the layers of algae to chlorine to kill it faster.
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    I'm going to try lying on the diving board and leaning over as far as I can to see if I can get to it. This should be funny.
    Wendy
    TF-100 Test Kit
    38,507
    Sounds like you need a longer pole.
    Jul 2014
    Independence, KY
    234
    Agreed that you need to get a longer pole. This will not only help with the slam, but with long term maintenance. You should brush your pool regularly, and if there is a large area you always miss, it might cause you some long term aggravation.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    duck tape a broom on to the pole.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    You all can order your "I'm with Stupid" t-shirts now, with the fingers pointed directly at me. I thought I had my pole extended as far as it would go, but it was only stuck. I got a good extra two feet on it today. w00t! NOW the entire pool has been brushed.
    Wendy
    TF-100 Test Kit
    DFW, TX
    24,513
    Nice! Problem solved.
