Thread: Running VS Pump During Breaking Period
    Mar 2015
    Las Vegas NV
    460
    I'm through my first week of break-in where pump runs 24/7. I believe now I'm in circulation/skimming mode only. I'm running my pump at 1100 RPM for 12 hours. Does this seem reasonable for the remainder of my break-in period? Looking for maximum efficiency yet proper daily water circulation.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Jun 2015
    Ottawa/Ontario
    340
    Re: Running VS Pump During Breaking Period
    I have read that you should strive to replace 1 1.5 total volume of pool water each day. The easiest way to figure that out is to determine your pool volume and pump rate. Next multiply your pool volume by 1.5, and divide this number by your pump rate. The number you are left with is how long you should run your pump for in order to filter that volume of water.
    Someone smarter than i may correct me though
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Jun 2015
    Ottawa/Ontario
    340
    That should be 1 to 1.5 total pool volume/day
