Thread: Stipid question about gauges
    Jun 2015
    jacksonville fl
    11
    Yep i'm new to pools.
    In all other things in life the pressure gauge reads delivery psi. But it seems that the gauge onthe filter is reading back psi. Is this correct?
    Should I assume that the higher psi on the gauge is worse?
    14000 gal kidney shaped in ground with spa. Paramount V3 pop up cleaner with six zones.
    1 Hp 1 Speed Reliant Pump. Pentair cartridge filter. No heater yet. uncovered.
    Jacksonville Florida
    22,550
    Re: Stipid question about gauges
    You are correct. The gauge on the filter is actually on the dirty side of the media, so it reads back pressure caused by the media and rises as it clogs. So yes, higher is worse.
    Jun 2015
    jacksonville fl
    11
    Thanks for the quick reply. I would assume that I should have just the valves to return as much water as possible to the pool by making sure the gauge reads as low as possible
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    you are correct agin
