Results 1 to 16 of 16
Thread: Very fine dust all over my pool :(
    Jun 2015
    Iowa
    29
    I just moved into a house with a pool, it was cloudy when I moved in but I fixed that just by back washing the filter. Crystal clear water
    Then it rained, very hard. I'm at a bottom of the hill and all sorts of dirt got in. I've been vacuuming to waste for a week now. The heavy dust is all out of the pool now it is just REALLY SUPER light dust. Barely getting close to it and all the dust moves. My water is so brown I can only see the first step of my pool. Do I just continue trying to vacuum or is there something else I can do?
    I ordered a robot but it won't be here for another two weeks as they are on back order.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Very fine dust all over my pool :(
    Hi, welcome to TFP! You need to complete the SLAM process on your pool to kill off any algae that may be growing. Do you have a test kit?
    Love TFP? Become a
    TFP Supporter!
    Jun 2015
    Iowa
    29
    Yeah, I have a test kit. I will run the test when I get home.
    Jun 2015
    Iowa
    29
    FC - 3
    PH - 7.0
    Alk - 50
    CH - 100
    CYA - 45
    So, start with raising my PH and begin the SLAM or should I raise some of the other stuff as well?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Just raise your pH to 7.2 and SLAM it. Don't worry about anything else until after the slam is over.
    Divin Dave,
    30,411
    A pic of your pool water would be very helpful.
    Do not be discouraged if your pool is still brown after several days. Your filter should be running 24/7 and you should be brushing, backwashing, etc.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    What type of test kit are you using?
    Jun 2015
    Iowa
    29
    Well thankfully when I got home I noticed my water is now green instead of brown. So I'm making some headway on getting most of that dirt out as I see it. I got the PH up to 7.2 now, so I'll begin the SLAM shortly. Pictures incoming.
    I vacuumed about three hours ago, the stair was completely covered in dirt, now, just a bit is left.
    1Google Photos
    2Google Photos
    Jun 2015
    Iowa
    29
    Quote Originally Posted by PAGirl View Post
    Taylor K-2006
    Jun 2015
    Iowa
    29
    Before I went to bed, my FC was at 16.2. That was at 10:30pm. I woke up at 6:15am to check my FC again, this time it was at 15.2. I was expecting more of a loss than that. I've been running high FC for awhile now, but not based on SLAM at the time. For the past week I've probably had it around 10FC, but I didn't have my test kit at that time. Only based on the one test I had Leslie's run for me. (wanted the $5 coupon for the free water test)
    Water is still the same, green. Didn't get much of a change on the dust level on the stairs though usually by morning it is completely covered again. I brushed the sides of the pool this morning before work. I would of done the floor level but I didn't have that much time.
    Would post a picture but it looks exactly the same it did last night when I started.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    How many gallons does your pool hold
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jun 2015
    Iowa
    29
    Quote Originally Posted by Defgufman View Post
    23,000
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Welcome to TFP! Please add your pool info to your sig as shown here, Pool School - Getting Started
    Jun 2015
    Iowa
    29
    Update: Pool is a very pretty teal color right now. I can see through to the shallow end (about four feet).
    Jun 2015
    Iowa
    29
    My pool SLAM is finally done and passed OCLT. Do I wait for my FC to drop back down to normal levels before balancing out everything else?
    23,000gal IG plaster, Sand filter
    30,411
    Yes. Let your FC drift down on it's own. When it goes below 10 ppm, please post a complete set of test results.....you'll probably be done but that last set of results is important.
    How does your water look? Got a pic? We love to see 'em if you do.
