Thread: Holes in vinyl liner
    kevin11's Avatar
    May 2015
    Northeast,Alabama
    50
    Just noticed today that I have two holes in my liner. One is about the size of a dime with a tiny small crack in the bottom of the hole. The other hole is half the size of the first one. Both are just above the water line. The liner looks pretty old. It's all white below the water line. It's not brittle though. What is the best way to repair a small hole so it does not become a big hole. Vinyl patch,some type of epoxy or some type of sealant? I'm going to start saving for a new liner now! Hopefully this one will be okay for a while longer.
    18x36 IG, Vinyl, 20K Gal., Sand Filter, 1HP pool pump, 3/4HP slide pump, Taylor k-2006.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Holes in vinyl liner
    Home Depot has a patch kit that works great. You can even put it on under water!
    Make sure your patch is bigger than your hole and had rounded sides.
    Kim
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Use Boxer brand adhesive with your patch
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    22,553
    You can also go to a local pool store or installer and see if they have some scraps of liner you could get. You may even get lucky and get a matching color. I agree with the boxer adhesive too.
    kevin11's Avatar
    May 2015
    Northeast,Alabama
    50
    Thanks, I will check with the pool store and see if they have some old liner that matches.
