TA is mostly a measure of bicarbonate in the pool and is a measure of how over-carbonated the pool water is compared to carbon dioxide in the air. When the TA is higher, the pH lower, and/or there is more aeration, then there is more carbon dioxide outgassing and that has the pH rise (with no change in TA). So if a pool is tending to rise in pH and it's not from other sources (such as plaster curing), then lowering the TA and having a higher pH target will lessen the rate of pH rise. Using 50 ppm Borates as an additional non-carbonate pH buffer slows down the rate of rise, but may not lower the total amount of acid that needs to be added (so you still add it, but less often).
