Thread: Help clearing green pool
    Jun 2015
    graham Texas
    1
    Split by moderator from HERE. jblizzle
    We have the exact same pool and color of our water !! We don't even understand where to begin or what to have on hand ! I don't know if we should just start dumping bleach or what . Our pump is a 1 3/4 horse power sand filter . It's big . We've tried shocking and vacuuming to no end and back washing and it's still not crystal clear . HELP !
    38,548
    Re: Help clearing green pool
    Welcome to TFP!!!
    What test kit are you using?
    Please post up a full set of test results.
    Also, add your pool details to your signature as described HERE as it will help us help you.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I assume when you say shocking, you are referring to a single application of a bunch of chlorine. You need to get your pool up to shock level and keep it there until it clears. You may have to test every few hours so that you know when to add more. Stick with Bleach or Liquid Chlorine so that you do not wind up with other issues. Do not let up until the water is clear, does not lose chlorine overnight, and has less than .5 ppm of CC.
    If you do not have a comprehensive test kit, you need to get one. TF-100 mentioned on this site is the best I have seen.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
