Thread: Cyanyric Acid
    Jun 2015
    Plainview NE
    6
    Cyanyric Acid
    I have been reading my Intec saltwater system instructions and it mentions adding cyanuric acid. I had not read any reviews that mentioned adding this acid; do I need to use this product? I have read that it helps condition the water. Where can I purchase it if I do need it? Is it also known as HTH?
    38,521
    Re: Cyanyric Acid
    That is what we refer to as stabilizer (CYA). It should be nearly 100% cyanuric acid and can be found in the pool section of hardware stores and Walmart.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    Jun 2015
    Plainview NE
    6
    Re: Cyanyric Acid
    Thank you I will check out the Pool School.
