Thread: New pump failed need help ASAP
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    I just purchased a new EchoStar pump. Took it out of the box and found out that one of the wires internally are ripped. I called Hayward and they are overnighting me a pump for my system . The pump won't get here till tomorrow or Wednesday the earliest before I took the pump out I disassembled the plumbing for the pool
    should I try to attach my old pump or should I wait for the two days when the new pump gets in
    what should I try to do????
    FYI. My water is in very good condition
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Dec 2012
    Manassas Park, VA
    207
    Re: New pump failed need help ASAP
    The best thing to do would be to brush your pool a couple times per day, this should be sufficient to circulate the water and mix any chemicals that you add.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Jan 2012
    340
    Plumb in the busted pump in the meantime so when you get the new one you can drop it right in.
    Ecostar has unions so should be a 5 minute install once plumbing is set.
    38,475
    Just maintain the FC with bleach and use a brush to thoroughly mix it in. I would not worry about hooking up the old pump.
