Thread: Small leak from pump -- worry? Don't worry?
    Jun 2008
    western Wisconsin
    250
    I seem to have a very small leak coming from my pump or the plumbing near it. I can't find the source. I know it's not one of the two plugs in the basket case (not sure that's the right term, but oh well) because the area near the plugs is dry.
    Any ideas for finding the source? The area around my pump is slightly wet -- not enough water to form a puddle. Should I worry?
    26000 gal, in-ground, vinyl pool
    Hayward S200 sand filter, 1 skimmer, 2 returns
    BBB since the first month! :-)
    Oct 2007
    Valrico, FL
    542
    Re: Small leak from pump -- worry? Don't worry?
    Yes. Might be coming from the seal between the pump and the motor. Over time the housing of the motor will rust out and also the front bearing will be damaged. The bearing can be replaced, but the motor housing will require a replacement motor.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    You can replace the seal yourself with common hand tools. The whole job might take 2 hours.
    There are several You Tube videos showing the seal replacement.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Jun 2008
    western Wisconsin
    250
    So, call the pool store? Would they automatically replace the motor, or some other part? Is there any other option than incurring a huge bill for a very small leak?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I just had mine replaced from a pool store and they charged $ 28
    Though I did have 3 other small leaks (drain plug for sand filter needed tape, replaced a check valve and taped threads on multiport)
    the total bill was just below 300 (he had to cut/make a new check valve fitting) but the pump seal was 28.
    You should just call a good local shop and tell them you have a leak.
    If they charge $ 97 an hour like my place does then I think total would be about $ 125
    You definitely want that fixed. Any leak can become a huge problem potentially that might end up costing way more later.
    Dolphin E10 Cleaning Robot.
