Results 1 to 7 of 7
Thread: Adding Chlorine & Acid with high CYA levels?
    Jun 2015
    Glendale, AZ
    156
    I have a couple of questions if anyone can help...
    My latest readings:
    FC 8.0
    CC 0.0
    pH 8.0
    TA 110
    CH 350
    CYA 160 (I know should drain, will this late fall)
    Pool Temp 90
    PoolCalculator recommends to get to these numbers:
    FC 14.5 add 65oz 12.5% bleach
    pH 7.2 add 30oz 31.45% acid
    If I understand correctly adding 65oz of chlorine with these numbers does raise the pH.
    My question is should I add more acid than is recommended because of this or does the Poolcalculator take that into consideration?
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Adding Chlorine & Acid with high CYA levels?
    The pH rise due to bleach addition is a temporary one and over the lifetime of the product added until the FC is consumed, is a pH neutral process. No need to compensate for pH changes due to liquid chlorine/bleach addition.
    Do the acid addition first. Verify you've reached the proper pH after circulating for 30 minutes to an hour, then proceed with bleach addition after that. The pH test is not accurate above 10 FC.
    Be sure you're using http://www.troublefreepool.com/calc.html not the outdated pool calculator link that is not supported by this site.
    Isolated Spa - 345 Gallons
    Mar 2007
    San Rafael, CA USA
    12,082
    I disagree. If you intend to keep your FC at the 8 ppm level then you can adjust the pH to where you want it to be. While the pH drops from chlorine usage/consumption, you don't intend to let your FC drop back towards 0 so the elevated pH you have now will be permanent as long as you keep your FC higher (i.e. the pH drops as FC drops, but then rises again when you add more chlorine to get the FC back up). Therefore, I would adjust your pH downward some.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    i think JVtrain was saying to adjust the pH first, since after he adds chlorine it will be over 10ppm and the pH test isn't accurate.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by chem geek View Post
    I actually intend to get the chlorine up around 14.5 ......I only let it get down to 8 or 9 to check the pH level, then kick it up to this. So if I check now and I am at 8.0 chlorine and will add 65oz of 12.5% bleach, should I then add more than the recommended of 30oz of 31.45& acid?
    After adding the acid and then the chlorine I want the pH to be around 7.2
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by DaninFLA View Post
    In that case I misunderstood. Thanks for clarifying.
    oldguy70, based on what you are saying, yes I'd have the pH be lower at your 8 ppm FC level since you intend to get it higher, but it's not a big deal since it's not a huge increase. If you started at a pH of 7.5, then with your numbers (TA, CYA) getting to 14.5 ppm FC would have the pH rise to 7.67. If you started at 7.8, however, the pH would rise to 8.1. If you started at 7.2, it would rise to 7.29 so that's probably lower than you intend (unless you wanted to lower your TA level some).
    Jun 2015
    Glendale, AZ
    156
    I think I understand....thank You
