Thread: Salt test low
    May 2015
    Lincoln
    2
    Salt test low
    I installed the pool 8 days ago. Pool math calculator said to add 217 lb of salt for 8640 gallon (using the manufacturer's stated volume). I added 200 lb of solar salt from HD. I tested the salt yesterday using the Aqua Check Salt Strips from TFTestkits.net. The indicator on the strip was just above 1. Expectation would be around 5. Strip was placed in a clean glass and water sampled elbow deep. I waited 5 minutes, 10 minutes, left in for 30 minutes observing changes.
    Not sure if I did the test wrong, I am reading the results wrong, or the strips are bad. The SWG is not complaining about the salt level. My options are to add salt, purchase another test method, or do nothing. Suggestions?
    FC - 4
    PH - 7.5
    CYA - added 3 lb, have not tested yet
    TA - 210 (have done one round of lowering with muratic)
    CH - 220
    Mark
    20'x52" Intex AG. Intex sand filter. Intex 8110 SWG. TF-100 test. Installed on level concrete and 1.5" foam.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Salt test low
    If the SWG is working fine then I would not worry about it too much. A better test for salt is the K1766 salt test that is linked in my signature.
    Also if you do get a low salt alarm before adding salt check the cell to see if it needs to be cleaned first. I learned this the hard way a couple years ago and had ocean water...lol
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Salt test low
    It takes at least 24 hours with the pump running for salt to dissolve. A little brushing will help too. Give it 48 hours and see what the SWG says. If it is happy and making chlorine then we are all happy. Also, salt tests are +/- 400 ppm.
    May 2015
    Lincoln
    2
    Re: Salt test low
    Thanks for the suggestions. The salt measurement was taken 8 days after the salt was introduced to the pool. The "1" reading on the strips equates to less than 400 ppm, whereas the "5" is closer to 3000 ppm. So, the strips say there is no salt in the pool. I am leaning towards Lisa's suggestion of do nothing at this point. I will look into the K 1766 test, although it is frustrating to have purchased such pricey strips that appear to not work well.
    Jun 2014
    Scott City, MO 63780
    5
    Re: Salt test low
    First, your TA is way to high, should be 100ppm max for SWG pools. 3lbs CYA should get your reading to 45ppm which is okay for SW pool. Each one has their opinion concerning products to maintain pools, but I bought a K-1766 salt kit, and it registered 800-900ppm too high in salt content. My SWG kept the red light on for low salt, I got new Aqua Check salt water strips, as my old strips were out of date, and would not read. and added salt according to the strip settings and the low salt light went out. I have found out that strips kept in a controlled setting will last much longer toward reading salt content. Also, Morton Solar Salt put in the shallow end an brushed back and forth with a pool brush will dissipate in a few minutes, wait for pool turnover before checking salt content. Just work at it, and the pool will come to you!
    30,424
    Re: Salt test low
    If you dosed a certain amount of salt, that is what your salt is.
    In other words, if you calculated your salt dosage to get to 3,000 ppm, then that's what it is regardless of ANY test.
