Results 1 to 10 of 10
Thread: SLAM in process, questions!
    Jun 2015
    Apopka, FL
    5
    Hello TFP Experts! I'm looking for some information/advice regarding my ongoing SLAM. I have read the Pool School info and the SLAM process information as well as purchased the TF100 testing kit.
    I initially set up my pool with a SWG but have stopped using it. I decided to do a SLAM because my water turned cloudy and would not hold chlorine. I began the process on Friday morning. I have been testing just about every hour during the day. My water is currently clear and upon testing this morning, the CC level was .5, however my overnight chlorine loss is very high! I have had to add at least 2 cups of chlorine upon each hourly test, and this morning I had lost 5ppm overnight.
    Additionally, it's been extremely hot (upper 90s) with no rain for quite a while and I'm losing water to evaporation. I'll need to add water to the pool very soon to continue running the filter.
    Here are my test results, taken just now, 2.5 hours after adding bleach this morning at 7am:
    FC: 20
    CC: barely over .5, one drop left the water with the barest tinge of pink
    CYA: 50
    Ca: 200
    TA: 154
    pH: 7.6
    My concern is that adding water at this point is going to throw a kink in the process and I'm wondering if there's anything I should know before I do. I'm also concerned about the dramatic continued chlorine loss even though the water has been clear for two days.
    Any insight you might have to share would be much appreciated! Thank you!
    Pool Info: Intex Ultra Frame 18x48 - 6400 gallons / Intex Sand Filter Model 28645EG - 2100 GPH / Pool filled from well
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: SLAM in process, questions!
    You are doing everything correctly. The addition of water won't throw the SLAM off.
    PH tests are not accurate when your FC is 10 or higher. You only need to test FC and CC during the SLAM.
    Even though CC has dropped, which is good does not mean your FC usage will drop right away. Keep at it and you will notice that it will start holding FC better.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    Apopka, FL
    5
    Quote Originally Posted by Azgirl71 View Post
    Great, thanks for the reassurance that I'm on the right path!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I would check the ladder carefully if it's still in the pool. Ladders provide lots of hiding places for algae. A backwash might not be a bad idea, either. And debris in the filter will consume FC as it tries to oxidize it away. Adding water will have minimal effect on chemistry. People with swamps have to add a lot to make up what they lose by hourly backwashes.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by canoeguru View Post
    Your welcome. The hardest part is passing the OLCT for most people. The key is to have patience and not stop too soon. I actually rand the OLCT 2 nights to make sure I was done...lol
    Lisa
    Jun 2015
    Apopka, FL
    5
    Thanks, Richard! Backwashed the filter and in the process of adding water. Appreciate your advice!
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    just wanted to add that your high FC losses are typical. it will slow down a little each day as long as you are staying on your FC. with patience you will win!
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Apopka, FL
    5
    Well, I had to be away for most of today. So I brought the FC level up to shock this morning and just tested it again and I've lost 8.5 FC during the day. I can't understand how I'm ever going to get my FC loss under control at this point if my normal recommended FC level is between 4-8 and I'm losing 8.5 FC during an average day My CC is within acceptable limits, the water is crystal, but it is just not holding Chlorine. I've used an incredible amount of bleach at this point!
    Richard320's Avatar
    Jan 2010
    19,074
    If there is no more algae hiding and the water is clear, you need to worry about the overnight loss test, not what it loses during the day. Your CYA is too low for the FC level you're maintaining. You're in the SLAM, not daily maintenance. That's way hiogher than normal levels. When it passes the OCLT, then you can allow FC to drop and raise CYA and everything will be smooth.
    Jun 2015
    Apopka, FL
    5
    Thanks, Richard. The pool calculator says my target CYA is 30-50, is that not correct?
