- Jul 3, 2013
- 9,028
- Vinyl
- CircuPool SJ-40
My apologies to everyone. This is a what if. My pool and test kit are fine.
I'm just wondering why so many threads advise to do nothing and wait, instead of "Hey when in doubt add liquid chlorine for the size of your pool (and assume some generalities about PH and CYA?)
Because there are no generalities, NONE... every pool is differant, every person taking care of said pool has added something differant...
example: Both do not have a test kit and are asking: How much chlorine do I add?
you use general ph of 7.2 and CYA of 50
owner 1 owner 2
ph6.4 ph 8.2
CYA 0 CYA 100
FC 0 FC0
20,000gal 12,000gal
you would need to tell them the following
Bleach
4 gallons 2 gallons
But this is really what they need
bleach
2 gallons 5.5 gallons
Do you see how far of you are?? this is a week before they get a good test kit. Imagine if they never get one???
Owner 1 probably bleached out there liner and wasted bleach because they used too much, 14 gallons over 7 days to much
and owner 2 wasted 2 gallons a bleach a day because they really needed 5.5 per day at that CYA level... They also needed to empty 60% of their water
I didnt even go into PH and what is needed to fix that...
When it does not work or something bad happens they will blame us for giveing them the wrong info..
flip the example
someones car wont start, they have no idea... you tell them to buy another battery, then alternator, then an ignition, then a new car... it was a blown fuse.... how much did you just cost them for a 50 cent fuse???????
