Results 1 to 12 of 12
Thread: Stenner Install
    Jun 2015
    Austin Tx
    65
    Stenner Install
    Hi Everyone. Our PB hasn't even painted the outlines on the ground yet but here I find myself already trying to get everything planned out. Here in Central Texas all of the pool builders we spoke to gave warnings against and would not warranty stone work around a SWCG pool. One even showed us damage photos of coping. None of them refused to install it but all gave warnings citing our softer stone and water type being concerns. In addition I have browsed the SWCG sub-forum and there seem to be a ton of problem related threads. That being said I realize there are probably a lot more SWCG installs than Stenner installs.
    Can someone elaborate on the level of upkeep for the Stenner other than just hauling the chlorine? I read in one thread someone talking about the hoses having a short lifespan, can someone elaborate on how often theirs have needed replacing? Have the prices of liquid chlorine gone up significantly over time?
    None of the PB's here would acknowledge or offer installation of the Stenner, they all wanted to push their version of an even more intelligent automation like Intelli-Chem or similar. That being said I believe based on all of the above I am going to install a Stenner after the PB is done. They are installing an EasyTouch 4 and I believe the PB will be using it for LED light, Pump and valve for sheer descent. So I assume I can use it to control power to the Stenner and then program it on a schedule?
    Gunite Phase || 16500 gal FreeForm 33'x18' IG, 89 perim, 491 sq ft. || Blue Surf Pebble Sheen || Pentair Intelliflo VS || Pentail C&C 520 || 2 Pentair Intellibrite 5G
    Previous Pool || 13500 gal. FreeForm 31'x19' IG, 87' perim, 481 sq ft.|| Pebble Sheen || Pentair IntelliFlo VS || Pentair C&C 420 || Pentair Intellibrite 5G
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Stenner Install
    I am at 18 months with mine. So far there has been no maintenance. I plan on checking out the index plate and dog in the near future.
    Support the site
    Mar 2015
    Sugar Land , TX
    424
    Re: Stenner Install
    Just a thought. When they install your EasyTouch box have them wire a GFI ( there is a knockout for it) on the side of the box so you can easly plug your Stenner into it. Make sure that GFI plug is connected to one of the circuits so you can control it with your EasyTouch handheld remote. Works like a charm for me! Oh and by the way with the Stenner doing the work you will have more time for Margaritas!
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jun 2014
    15,109
    Re: Stenner Install
    Hello sbpse! I see you haven't received a reply yet on your post about a Stenner install. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    22,549
    Re: Stenner Install
    I usually replace the pump tube every year, but they'll probably last two or more years. On the fixed rate models, there's not much to do other than that. On the adjustable models, you need to lubricate the index plate and dog about once a year, and you'll probably need to turn the plate over after a couple of years and replace it at probably 4 or 5 years.
    I have the black UV resistant feed tubing and it has lasted several years and is showing no signs of wear or aging.
    Jun 2015
    Austin Tx
    65
    Re: Stenner Install
    Thank you for the feedback.
    Jun 2015
    Austin Tx
    65
    Re: Stenner Install
    Sorry I couldn't post again because of the problem with the incorrect post timings.
    If they install a GFI plug connected to one of the circuits on the easy touch would I then be able to program power delivery to that circuit on a schedule?
    22,549
    Re: Stenner Install
    You should be able to program one of the relays to whatever schedule you want and they can wire a receptacle to it to plug the Stenner into. I'd use a single receptacle just to differentiate it from any duplex convenience receptacles in the area and to discourage someone from plugging something else into it.
    Jun 2015
    Austin Tx
    65
    Re: Stenner Install
    Good tip. Thank you!
    May 2014
    Franklin, NC
    9,184
    Re: Stenner Install
    Just make sure you order the same voltage as the receptacle they install. The stenner comes 110v & 220v.
    Support the site
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: Stenner Install
    I’ve had mine for almost 2 years and the only thing I’ve done in that time is replace the tube once and that was more a precaution than a necessity. Model number is in my signature.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Sep 2013
    Dallas/Fort Worth
    21
    Re: Stenner Install
    I'v had my stenner for 2 1/2 years. it's fantastic. Haven't had an algae outbreak since putting it in. Having said that, I did have to rebuild the motor on mine because water got in and rusted the moving parts. The water came from my sprinkler systems that shot water under the pump's provided rain hood.
    Dallas, TX. 27,000 gallon in-ground free-form gunite. Built in 2007. DEL60 filter with single speed 2hp Hayward pump. Polaris 360 cleaner with associated booster pump. Stenner chlorine pump and tank. Intermatic P1353ME timer.
