Thread: Beaded liner removal
    Jun 2015
    Claremore,OK
    1
    Is there a way to remove a beaded liner to reuse again? We are wanting to relocate our pool and reuse our 2 month old liner
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,668
    Re: Beaded liner removal
    If you do it quick you should be able to reuse it.
    -Get the new spot ready.
    -Over night drain the pool.
    - First thing in the morning take the liner out and put it in a shady spot CAREFULLY.
    -Put up in new spot and fill with water THAT same day.
    Good luck and have a beer waiting for you when the job is done!
    The danger of reusing liners is them sitting out over time-getting cold/hot and the folds in the vinyl causing cracks.
    Kim
