Thread: Draining Pool without doing backwash?
    May 2015
    Mississauga
    29
    We have had so much rain in the last two days that I have an extra two inches of water on my pool. So much that the weir door isn't working properly. So I need to drain water. But can I drain the water without doing a backwash? If so let me know!
    11.5K gal, IG vinyl, 3/4 HP Hayward Pump, Hayward sand filter, Hayward Chlorinator (Turned Off), Raypak Heater, Taylor FAS-DPD K2006C T/K
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Draining Pool without doing backwash?
    Yes you can. Just turn the handle to backwash and let it flow. You don't need the pump on.
    I have a pipe set up just to take water out. One day I will have a auto overflow system for just in case.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Set the multiport to waste. It will pump straight from the pool out the backwash waste port and take the filter completely out of the loop.
    Jul 2012
    Tallahassee, FL
    30,672
    Doh! I forgot about waste! Good catch Richard. THANKS!
    Kim
    May 2015
    Mississauga
    29
    Thanks!
    Jun 2015
    Tallahassee, FL
    30
    If it will backwash without electricity, why would you not? Waste is probably faster and easier but again why?
    Intek 18' X 48" AG, filled to 36-42"(slope?), Intek sand filter/pump, Hayward skimmer
