Thread: Do I need to "isolate" my sand filter from the system to deep clean?
    Jun 2008
    western Wisconsin
    250
    I want to deep clean (or at least rinse the sand in) my Hayward S200 sand filter. Do I need to isolate it from my system if I have an inground pool and the filter is above ground? If so, how do I do this? (I will need very simplified instructions. The multiport on my S200 is on the side.)
    26000 gal, in-ground, vinyl pool
    Hayward S200 sand filter, 1 skimmer, 2 returns
    BBB since the first month! :-)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Do I need to "isolate" my sand filter from the system to deep clean?
    I think if you just set the multiport to waste or off it will close the ports to the sand filter. Then nothing can get sent out the wrong pipe.
