Thread: Options for wireless spa controls?
    Jun 2015
    Fallbrook CA
    13
    Recent home buy, first pool/spa. I'm having the pool professionally maintained (good company) while I deal with equipment/pad issues. The spa heater, pump, and blower are energized by a spa control switchbox located a couple feet from the Intermatic control panel and mounted on a dilapidated wood fence which surrounds the equipment pad.
    Access to the switches under the switchbox cover is difficult as it opens to the middle of the wife's garden (other side of the fence).
    The Intermatic has some corrosion and rusting from water intrusion. It is also mounted on the same dilapidated wood fence.
    I'm replacing the fence and possibly the control panel, but then started thinking about replacing the inconvenient spa switchbox with a wireless control for the spa equipment.
    Does such a system exist? Suggestions welcome.
    21K gal, IG, pebble, DE 60sqft filter, Pentair 3/4hp circ pump, Rheem propane htr
    Intermatic T32404R panel, Hayward 2HP jet pump
    First time pool owner (finally)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Options for wireless spa controls?
    there are a lot of options and money is what will limit what you get I just did the Intermatic PE653RC Wireless Control System and I really like it.. it is wireless and has 5 buttons/options.. the wireless range for me is about 50 feet through a brick wall and through a 2x10 board.. I paid to have it wired in by an electrician...
    I used the following
    1 high speed pump
    2 low speed pump
    3 salt water generator
    4 open
    5 led 12 volt power supply
    this is the remote and brain
    http://www.intermatic.com/~/media/In...Wave/PE953.jpg
    Jun 2015
    Fallbrook CA
    13
    Nice layout, thx for response. Any other options?
    Jan 2012
    340
    You can take a look at the Pentair SunTouch. Another simple automation system that can be used with the wireless QuickTouch remote. Simpler than the intermatic controls IMO.
