Thread: Adjust CH? Is that all -- new water chemistry question
    corporate_zombie's Avatar
    Oct 2014
    Humble, TX
    47
    Hi…we just built a new pool, and it was handed over to us on 6/19, so I've been working on it for a week. I made the first trip to Leslie's last week for muriatic acid and I did get some tricolor pucks (more on the WHY of that later…but there is a reason). I live in Houston, and aside from all the rain during our build, it has been hot. I have had to add water once (yesterday, and then it rained REALLY hard last night) -- so I was worried about the chemistry this morning. I am not sure on the actual gallons of my pool, but I have been using 22K gallons in pool math (when I had to add MA) and it worked
    So here are the numbers (yes, I have the TF-100 test kit)---and I've been testing almost everyday, just to get familiarity with the tests and making sure I am not missing anything (and because, it is kinda fun and exciting too!):
    6/20: FC=.5, CC=.5, TC=1, CH=200, TA=120, CYA=30, pH=8.2. I immediately dosed with bleach and acid and freaked out on this day b/c the chlorine was so low and the pH so high. PB had been using tricolor pucks in the rainbow, but had dialed it back to a "2" and it was not enough!
    I'll skip the next couple days (unless someone asks for the results, but it is more of the same as above, except that FC went to 4, and CC went to 0, and pH 7.5)
    6/26: FC=6, CC=0, TC=6, CH=175, TA=120, CYA=30, pH 7.8
    6/28: FC=3 (additional water add and lots of rain), CC=0, CH=150, TA=110, CYA=30, pH=7.8
    I added chlorine this morning, after the rain -- but honestly, I didn't measure it out perfectly. I only had what was left in one jug, so added it and thought I will check it again this evening, when I get more bleach. It was about 64 oz, and pool math said around 96oz to get to 6. I am about to run up to the store and get something for the CH, I looked at pool math, and I either need 22 lbs of one or 30 lbs of the other type of calcium chloride.
    I guess I just want to make sure I am looking at this correctly, and doing this right? Does this make sense.
    Also, on the trichlor pucks I told you I purchased…we are going on vacation for 2 weeks out of the summer. I plan to use the pucks in the rainbow while we are gone. If my CYA goes up due to them, I think it is ok because I am only at 30 right now. I don't want to raise the CYA with stabilizer right now, just for the vacation issue. I want to make sure that my thought process is ok for this too -- it is ok to keep CYA on the very low end, knowing that I will raise it in a couple weeks, and then again in early August. The way the summer is here, I am going to be adding water throughout the summer anyway.
    Ok, I think those are all my water chemistry questions for now. My only other thought is that, I may have gotten the FC and CC wrong on the first test, because it was the very first time using my test kit…but whatever I did, seemed to not "hurt" the pool. And the water is very blue and sparkly, and clear at this point. Oh, and one more thing…that CYA test is tricky. I really don't know if I am doing it "right"…I mean sometimes I think I can see the dot, but then sometimes I think I am imagining that I see the dot b/c I know it is there...
    I hope I didn't forget any pertinent facts…
    Complete! IG freeform pool and spa, 106 linear feet
    All Pentair: Pump Intelliflo 4X160, 520 sq ft cartridge filter, Rainbow 320, 400K BTU heater, Racer Cleaner
    Pentair Easytouch remote, Aqua Blue Pebblesheen
    Additional: 2 weeping walls with moss rock, 12'x14' pergola, 1000 sq ft decking
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Adjust CH? Is that all -- new water chemistry question
    Running low CYA to allow pucks later just shows you understand things.
    I've never had to add CH to my pool, can't help you there.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Have you tested your tap water for its CH level? I would check that before you take it too high. If your fill water is high CH you will be getting plenty every time you fill the pool.
    What is Leslie's charging for the acid? Lowes is about $7.50 a gallon.
    Support the site
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    In my previous years with a pool in Houston, I think I added a few pounds of CH about once a year. Including the 8 lbs I just added this afternoon (that was some rain last night, eh? And the thunder....freakin' awesome!), I think I've added 35 lbs. since the beginning of May!
    The good news is that CH and CYA pretty much track together. Once you get your pool chemistry lined out, you can measure just one of them and automatically know what's happening with the other one. It's much more expensive to measure CYA than CH, so I only do a CYA test when I think I'm ready to add some stabilizer.
    Looks like you're doing great; good luck with the new pool!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Oct 2014
    Humble, TX
    47
    Thank you, everyone!
    And Tim5055 -- I think it was around $13 for the 2 jugs that were in the case. I can't find it at my Lowes/Home Depot/Walmart.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by corporate_zombie View Post
    $13 for 2 gallons is a good price. The big box stores usually keep it in the paint section.
    Support the site
