Results 1 to 7 of 7
Thread: BioActive Try
    Jun 2015
    Northridge
    8
    BioActive Try
    Hi All-
    Newbie here. I am in the midst of lowering my cya by using bio-active. I have a K2006 test kit and it shows the cya to > 100 so I diluted the solution (fresh water and pool water) to about 3:1 and now it measures around 70~80 in the cya vile. So I guess the translates to cya level of 240. I have for YEARS been using those stinkin' little tri-chlor tabs and have totally screwed my pool chemistry. I have learned this by subscribing to this website.
    But, I live in sunny, drought stricken southern California and dumping water just doesn't sit well for me knowing what a water crisis we are experiencing. So, I am hoping the bio-active product will work.
    Which btw, this thread had mention of bio-active, but I haven't found results about using the product on this thread. I'll create another thread rather than hi-jack this one.
    Northridge, CA
    36x18 - 25,000 GAL. IG Plaster
    PAC Fab 36 sq.ft DE filter, Pentair InteliFlo VF variable drive
    Old school Kreepy Krawly, Polaris 360
    Taylor K2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: BioActive Try
    We wish you luck! We really want to see this product work, but if you look around the Deep End Forum you will see multiple attempts with little positive results.
    Welcome to TFP!
    Support the site
    Ellington, CT
    262
    Re: BioActive Try
    Quote Originally Posted by bbayer View Post
    ...to about 3:1 and now it measures around 70~80 in the cya vile. So I guess the translates to cya level of 240. .
    A 3 to 1 dilution results in a multiplication factor of 4, so it more like 280 to 320 ppm
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Jan 2014
    Buckeye AZ
    807
    Re: BioActive Try
    IIRC most of the tests done here have been at the bottom end of the recommended water temperature for the product, so a mid-summer application will be a nice test.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: BioActive Try
    Hopefully it works well for you.
    I was near the bottom acceptable temp and only had a reduction of 20 ppm.
    My CYA was around 90 so I'm at 70 now.
    Oh and I had a mustard algae out break occur right after the bio active trial, so
    be prepared for that. Took a 2.5 week SLAM to clear out the mustard. GGRRR.
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Northridge
    8
    Re: BioActive Try
    Well, it's been five days since I added the Bio-Active.
    So far I haven't seen any reduction. Just for the record:
    FC ~ 1.5 to 2.0
    CC .5
    CYA still measures between 70 and 80 with a 3:1 dilution
    So there you have it. I will sample again on the 10th day in case those little bacteria are planning a surprise party!
    Even with the FC so low, no algae to report.
    Probably will up the chlorine to 2.0 tomorrow.
    Thanks All.
    Northridge, CA
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: BioActive Try
    Thanks for reporting. We've definitely had the vast majority of people trying this have little to no success, unfortunately.
