Results 1 to 10 of 10
Thread: Circulation Dye Test
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have been wanting to do this test for some time but haven't gotten around to it until now. I ran three tests:
    1) Dye in front of return at high speed
    2) Dye in from of return at low speed
    3) Dye in skimmer coming out of 4 returns at high speed
    The only issue was that the dye faded pretty quickly from blue to green because my FC levels are currently above 5 ppm. I think the dye is meant for much lower FC levels. The videos are saved as 10x so each min represents 10 min real time. Anyway here are the results and a few comments:
    Dye in front of return at high speed - Note dye change at 5 min (0.5 min video time). Full distribution less than 30 min (3 min video time).
    Dye in front of return at low speed - Note dye change at 20 min (2 min video time). Full distribution less than 60 min (6 min video time).
    Dye out of 4 returns at high speed - Note dye change at 5 min (0.5 min video time). Full distribution less than 10 min (1 min video time).
    I might try this again in the winter when I can let FC drop.
    Dye: HTH party potion at Walmart.
    Mark
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Circulation Dye Test
    Very interesting experiment. It's great to get a visualization of the spread. Thanks much.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    38,301
    So would you think that only running the pump 30 minutes after adding bleach / acid on low speed is not enough then?
    I mean certainly it would be better to add chems with the pump on high.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Because of the dye color change, it was really hard to tell when the dye got to the shallow end. That was my best guess but it probably occurred earlier than 60 min. But then again, high speed results seems to indicate something a little less than 30 min and I would expect low speed to be about 2x that.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    One could add chemicals slowly over each return in rough proportion to the volume of water in the area so more in the deep end than the shallow end. That way one gets most of the effect of putting it into the skimmer without sending concentrated chemicals through the pump, heater, filter.
    In my pool I found that pouring over a return flow in the deep end at higher speed (48 GPM as opposed to 26 GPM for total flow rate) was mostly mixed at 10 minutes but continued to mix until 20 and was completely mixed after 30. I used FAS-DPD to measure chlorine levels for my test.
    Brushing the pool after adding chemicals speeds up the distribution quite a bit.
    Support the site
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Now I know I'm not totally crazy because I do exactly what chemgeek said. I have 5 returns and pour some in front of each return. I must be mixing really fast, expecially if I take a swim shortly after.
    Dallas, TX
    109
    Thanks for doing and posting!
    30k gallon IG PebbleSheen refinished 2014
    60sqft FNS Plus DE wih Proguard Cellulose, 1.5hp 2speed WhisperFlo
    TFTestKit and Stenner fixed 10gpd on timer with bleach
    Dolphin m500
    Oct 2015
    Katy/Texas
    411
    What kind of dye did you use for your tests?
    Where do you buy it?
    I would like to do the same kind of test for my personal entertainment.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Hth party potion at walmart.
    Mark
