Thread: Pentair Compool lx3400 not working correctly
    Jun 2015
    Grand Prairie, Texas
    36
    For the past couple of weeks I have run my pump continuously to clear green algae. Although all of the lights work on my Compool lx3400 control box the pump only works when I turn my circuit beraker on/off. All of the lights are on (auto, service, filter, spa, back wash, drain, fill...etc) but when I press them nothing happens. Has anyone run into this issue? Am I looking at having to purchase a new control box?
    21000gals/in ground/plaster/pentair pump
    Casey's Avatar
    SW PA
    10,427
    Re: Pentair Compool lx3400 not working correctly
    Welcome to TFP. So sorry you're having troubles with this.
    Someone will be along to help you. We'll get this bumped to the top so someone will see it.
    Hope you enjoy TFP.
    Jun 2015
    36
    Thanks
    Dec 2014
    Riverside California
    482
    Look into the Pentair Easy touch upgrade. Very easy to do and will be better than trying to repair the old Compool. Just upgraded my older than yours LX10/Timemaster. I am very happy with it. Also look into adding a ScreenLogic interface. Your old remotes will not work with Easy Touch.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2015
    36
    thank you
