Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Saltwater green tint
    Jun 2015
    Portland, oregon
    10
    Hello, I am new to a saltwater system. I have a 18x48 Intex Ultra Frame pool. I set it up added the required amount of salt ran the filter pump and left it on for over 12 hours making sure all the salt was dissolved before turning on the saltwater system. Yesterday is when I started the system on boost. The pool was clear all day yesterday and the kids have been swimming in it. Today I woke up system still on boost and my pool water has a green tint to it. It does not look cloudy and I do not feel any alge on the sides of the pool.
    Here are my test results
    total hardness in 100 range
    total chlorine in 1 (ok) range
    ph in 7.2-7.8 range
    total alkalinity in between low and ok range closer to ok range
    stabilizer in between 0 and 50
    Some stuff I've read on line says maybe metals in the water could this be the case? How do I fix this? It's Sunday and all the pool stores are closed. I did turn off the boost just now. Is it safe to let my kids swim? Also can I ever get the water back to clear blue without emptying it out?
    38,305
    Re: Saltwater green tint
    Welcome to TFP!!!
    First you need to invest in one of the Recommended Test Kits because a stabilizer range of 0 to 50ppm is not even close to accurate enough. Did you add any stabilizer? If not, you need to.
    A clear green tint could be due to iron in the water that shows up when you add chlorine.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    And here is some reading about Dealing with Metals in your Water that list the recommended sequestrants.
    Jun 2015
    Portland, oregon
    10
    Thank you for the response.
    I just bought the test strips and the color on the strip is in between the 0 color and the 50 color. I have not added anything other than salt.
    38,305
    And that proves how bad test strips are. Tap water has no CYA in it.
    Jun 2015
    Portland, oregon
    10
    Thanks for the info. Man this pool is costing more and more. I've had a chlorine pool before this year and wanted to switch to saltwater to have crystal clear water with less maintenance seems I was wrong maybe? Why can't I just have clear water???? Last few years it was constant checking and adding chemicals and it looks with this it will be the same.
    38,305
    Following our methods, it is normal to test and add chemicals daily.
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by Jenmab33 View Post
    You're not wrong, you can have crystal clear water for little effort and cash. You have to be committed to make it happen.
    Stay the course...
    I've had my swcg pool for 3 years now and spend very little on it. The key is getting the recommended test kit, ensuring you actually followed pool school formula( I didn't the first time) then once you are balanced you're golden.
    I do nothing to my pool now, other than a simple set of tests((chlorine, Ph) every couple days. You can literally look at the water and tell the Ph is high( not as crystal clear). Test and put a bit of muratic acid in(pool math). You have to stick it out in the beginning to reap the rewards.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jun 2015
    Portland, oregon
    10
    I feel the green color has to be from minerals in the pool since it's only been up for less than 3 days and it's clear except green tint and it's not slimy. Would it be unsafe for us to get in it? I can't get the water tested until tomorrow.
    38,305
    Well, we do not trust pool store testing either ... so go ahead and order a good kit.
    It is safe to swim in the water (you shower in it ), as long as the FC is in range for your CYA level. But if you have not added any CYA, then it is zero and you will lose all your FC to the sun every day. you should supplement with bleach until the CYA gets up and the SWG can keep FC in the water.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Buy the recommended test kit, you will not regret it and follow the instructions of the experts here, is the best thing I did
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2015
    Portland, oregon
    10
    Thanks I will buy some stabilizer tomorrow my chlorine level is fine right now.
    Jun 2015
    Portland, oregon
    10
    So weirdest thing woke up this morning and the water was not as green. I hadn't put anything in it and I had to go to work. Haven't ran the saltwater system either. Tested before work and no chlorine. On my way home from work I bought stabilizer and a bag of shock. When I got home the pool was blue but no chlorine. Threw the shock in and stabilizer and turned on the saltwater system all seem clear now and chlorine is good. Weird?
    38,305
    So why are you throwing in bags of "shock"? Do you know the ingredients and account for all the things it would impact?
    You should use bleach to supplement the chlorine.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,534
    TFP is a methodology that can be used to determine exactly what to add to your pool and exactly when to add it. But in order to do so, you need precise water quality test results, which is why test strips are not considered suitable.
    Randomly tossing chemicals into your pool leads down a very frustrating and expensive path.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    Portland, oregon
    10
    the person at the pool store told me I should. It was one bag and ever since then all levels have been fine water is clear.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Jenmab33, you are really going to have to decide whether to take the advice of the people on this forum or the pool store's. They are incompatible with one another. I've used the TFP method for over 8 years, without a single issue. And the costs to do it this way are so much less compared to pool store chemicals. But, if you want to follow this method and get good advice, you will need to purchase a recommended test kit. Strips do not work! You are really wasting your time if you come here to ask questions and then throw in your pool whatever the pool store says to do. These guys can get your water in great shape, but you have to follow their advice!
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Jun 2015
    Portland, oregon
    10
    Quote Originally Posted by PoolESQ View Post
    I'm a little confused I didn't know this site was for only a certain method of pool balancing. I also didn't know there was multiple ways of balancing your pool water. I figured if I went to a store that specialized in pools they would know what they are talking about. I guess I still don't really understand what this TFP method is. Is it just buying a test kit? Cause that's all I keep hearing about. I need to buy a $50-$100 test kit cause THE STRIPS DONT WORK. Are the chemicals or whatever they are different from what you would buy at a pool store?
    38,305
    The chemicals are identical, but not marked up for the fancy package when you buy in the grocery store instead of the pool store.
    Pool store testing is horrible. Test strips are horrible. Search the forum and you can see it over and over again.
    The TFPC method is about KNOWING the chemistry of the water (using a good test kit) and only adding what it needs. It is a minimalistic approach where the testing is the cornerstone.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    The cost of the test kit seems a bit high at first. However, after using the methods here, the money you save by not buying unnecessary chemicals more than makes up for the cost of the kit. I've been using it for three summers, it works, but you have to follow the recommendations in Pool School, otherwise it won't.
  20. Back To Top    #20
    30,421
    That seems very logical. Unfortunately, there is nothing further from the truth. Pool Store Employees simply do not have adequate education.
    I agree. The TFP method is about teaching YOU to take care of your own pool and not to rely on someone else's inexpert opinion. We teach you to manage your pool because we teach you to understand the basics of pool water chemistry.
    Having a good test kit is an essential step towards that understanding.
    I "hear" your skepticism. The choice is entirely yours but if you continue to read on this forum, the success stories are undeniable.
