Thread: Preferred O-Ring Lube?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Hey all,
    What O-ring lube do the professionals on here suggest using? I've used some stuff the past two years called something like "Magic Lube O-ring lube w/ teflon", and it has a tendency to gunk up on the O-rings and mating parts and is a royal pain to try to get off. My PB left just some plain silicone lube which was great, but I ran out and can't seem to find it around here.
    TIA,
    Mike
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Preferred O-Ring Lube?
    Magic Lube comes in both teflon or silicone varieties. I use both, but prefer silicone for o-rings. The silicone version is technically "Magic Lube II" and has red letters instead of blue.
    http://www.pfpros.com/pond-liners-aladdin.shtml
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    You da man! Thanks!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    Coastalish 'down easter'
    4,160
    I have used all sorts of lube, and even some of it on pool part O-rings
    I've seen the 'gunkyness' of the teflon lube and, while it's somewhat of a PITA - what I've noticed when using the silicon stuff is that my fingernails get 'soft' and easily torn and flaking (not brittle) - they seem to peel off in layers (NOT the whole nail - just the front part where you would trim them)
    Mike, as you or most pool owners don't apply a tube or two a day, I don't think the silicon type will have the same, rapid, effect as I've encountered.
    Anybody know which kind Hayward's Jacks 327 is?
    Luv& Luk
    -Ted
