Thread: Chlorine questions
    Jun 2015
    Cleveland, Ms
    1
    Chlorine questions
    I just changed my 10,000 gallon above ground to salt water. It's gotten pretty hazy. I've put numerous chlorine tabs in the filter, shocked, but on my test strips, it still shows no chlorine levels. Am I using the wrong test strips? Is it a different kind of chlorine that the system produces?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Chlorine questions
    Welcome to TFP!
    Chlorine is chlorine, whether it is from tabs, the SWCG or a bleach bottle.
    Generally the water getting cloudy is the first sign that something is starting to grow,in the water, algae.
    Test strips are generally worthless for testing. You need a quality, accurate test kit to be able to follow our teachings. I recommend the TF100 at TFTestkits.net
    To follow our pool care recommendations you need a kit with the FAS-DPD chlorine test which most kits do not have. That test is generally not available locally.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Get the TF100 from TFTestkits.net.
    And balance your water according to this, Pool School - Water Balance for SWGs
    May 2014
    Franklin, NC
    9,184
    The SwG Water Balance article will come into effect after you get your pool clear. Don't add any CYA until after it is clear.
    Support the site
    DFW, TX
    24,450
    Yes, correct. If you have algae or don't pass the Overnight FC Loss Test (OCLT) then you will need to SLAM - Shock Level And Maintain your pool first to clear the algae and then resume normal pool maintenance.
